I'm a little confused. What is HID and what does their setup refer to?We'd be better off upgrading our HID setup
Yup. HALF of the 50W US ones....How did Tesla de-rate the lights? Is it just lower power bulbs?
Really? Why not just use US-spec bulbs? I'd be surprised if they're non-standard...As it stands today, we can't replace the bulbs in the current headlights afaik. Next higher assembly, per a local SvC manager, at $1,000 each, and it would be like for like - no LED if none with which to start.
Unless one follows the lead of the thread referenced above and replaces that assembly with headlights from a third party. Didn't see a price yet, though.
Yeah?
So can't we just order these on eBay or Amazon or something and just replace them?
Anyone care to source them for us?
NOOOOO.... I have yet to see them and frankly am not unhappy with what I have now. That is, I have not seen them on any vehicle and don't know what they do for you.Who is game enough to just order a pair of new LED headlights as a spare part, and rip out their existing headlights to see if the wiring and fit are compatible?
Dborn?
OK. Failed to read through the whole thread. Ztrekus, let us know how easy it is to fit those and of course, the results! Given we have no grille, not sure where the cooling air supply is going to come from. You might like to look around in there while fitting them. My experience with LEDs around the house is that the drivers tend to fail, not the LED itself.
Sounds like a deadset TREK to replace the bulbs, ZTrekus- thanks for being the tester!!
Dont forget the suspension can adjust itself whenever it feels the urge, so jack mode and a block of wood under the car to avoid being crushed.Hi Dborn,
My research tells me the access to the headlamp is...get this...through the wheel arch!!
Some have taken the wheel off and have worked under the car with a jack holding it up. That to me is sticking your head inside the mouth of a lion. No thank you!
Others say you put the air suspension on highest, you turn the wheel all the way towards the headlight you are working on, and you stick the car in jack mode (dunno why). Apparently you can then gain access to around 15 long and short and multiply different bolts and screws to remove a small panel, then you bend towards the wheel an even lighter panel under that (which is bendable) and you can then snake your hand around to gain access to the Gromit behind the headlamp. After removing that, you can unplug the existing crappy headlamp and plug in the hopefully magically wonderful LED. But I believe you have to make a small incision in the Gromit first to stick the bigger LED through (with fan and wiring on the back) then work out a place in the wheel arch to mount the LED housing. At least there is room back there.
Then if all goes well, we only have to worry about overzealous cops concerned about the amount of lumens the car is throwing out above the Aust design rules. But it will be cooler (no literally whiter and brighter) and if you were excited about those really small rear LEDs for the number plate...well then you just ain't seen nothin' yet!
Now I know Dborn that you have no complaints about the headlights because, as you say, you have nothing to compare them with. But I came from an LED Prius background, and that was sooo nice, that once you experience it, you just cannot go back. Why it's like comparing a Lemon with a Watermelon - and man am I thirsty!!
(Just thought of this argument so I have edited it on. When I bought the Tesla, I was immediately remorseful that the headlamps were so crappy. The Prius was such a pleasure to drive at night because of it. Toyota made a big deal that they were auto levelling, but actually that feature was a pure gimmick. Besides the Tesla air suspension is also self levelling so as far as headlights go, we have the same feature anyway. But the point is that - Tesla itself - has recognised this deficiency which is why obviously that they have now brought out LED headlights as an optional ex$tra. Was that the tail wagging the dog? Anyway IF a cheap and nasty solution is just a matter of changing two bulbs for less than a hundred bucks then I am definitely in... Now if only my hopes will not be dashed at the end of it... I don't think I could handle that...)
They would also need that version of the software.Bjorn has a video of the Model X lights which will be the same I assume. They basically have several stages of progressively side-aimed led lights within the headlight that come on as you turn the wheel in that direction. So basically a more sophisticated version of the old cornering lights and built in to the headlamp assembly.
I would also doubt that these are retrofitable since they'd almost certainly need wiring loom support that doesn't exist on the older cars.
