Can you run a PC from Tesla 12v with an inverter?
Discussion in 'The UK and Ireland' started by Yev000, Mar 1, 2021 at 12:18 PM.
  1. Yev000
    Yev000 Active Member
    Knaphill
    Got an idea to run my desktop PC while camping. Does anyone think it is possible to run it using an 500+W inverter from the 12v plug? Or is there a better way of doing it?
  2. GRiLLA
    GRiLLA Member
    UK
    A laptop?
    • Funny x 3
  3. Yev000
    Knaphill
    No a laptop will be easy. I want to see if my gaming PC would run VR in a field somewhere....
    So I need 5 plugs. 2 for base stations and 2 for pc, monitor and headset. Should 600-700w maybe? Maybe less.
  4. GRiLLA
    GRiLLA Member
    UK
    I hate camping too, but I put my foot down and refuse to go.
    • Funny x 4
  5. Medved_77
    Medved_77 TM3 SR+ | MSM+Black | No FSD
    Scotland
  6. Yev000
    Knaphill
    Not about camping.
    My room is ~ 4x4 meters and ceiling is ~ 2.1 meters. And It's too low and too small to really go all out in VR. I need something like 3 meter ceiling and 7x7 space... So football field somewhere would be ideal :D
  7. Mr H
    Mr H Active Member
    Manchester
    for that kind of consumption you need to connect directly to the 12v battery, there is a connection under the rear seat
  8. Yev000
    Knaphill
    Yeah, that's what I thought....
    Is there just the single 12v plug?
  9. Yev000
    Knaphill
    Dont you mean the high voltage battery? The 12v lead acid will probably die pretty quick.
  10. Yev000
    Knaphill
    What about the USB-c ports? is there something that can be done there?
  11. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    Based on posts in other threads, if Tesla finds out, they can void the warranty on the 12V battery.
  12. Mr H
    Mr H Active Member
    Manchester
    the 12v connection that feeds the 12v battery from the main pack is accessible under the rear seat, the 12v battery will be constantly topped up as it's needed
  13. tkizzy
    tkizzy Member
    Napa, CA
    I tried to run a cobra irad 200 from a 2015 model S that worked fine in other vehicles and the voltage seems to sag and it made a slowing down sound from high frequency to low freq and turns off after a few minutes. Haven’t tried in a couple years, dunno if that behavior could be fixed via software update....
  14. M3noob
    M3noob Supporting Member
    Beyond the pale
    Take a generator with you.
  15. paulk
    paulk Member
    hartford, ct
    i think the 12v plug is tied to a 15A fuse, so i wouldn't use more than 150 watts. if you want to attach a 500 watt inverter it should be attached directly to the battery with a fused connection, likely more work than you want to do.
  16. Yev000
    Knaphill
    Seems that way. Shame really. I guess I need a cybertruck with the connection in the bed.
  17. NewbieT
    NewbieT Member
    North West
  18. davidmc
    davidmc Active Member
    Leicester
    12v plugs if lucky can give 180w
    They don't have high amps 9-15amps if lucky. Model 3 i believe is around 12amps with around 16 peak out of the 12v socket.
    Also your PC - what is the power supply rating? 600w? or higher?
    The GPU will use most of the power is such as a Nvidia 3070 will consume around the 220w mark, especially in VR
  19. Durzel
    Durzel Active Member
    Bath, UK
  20. Plagued
    Plagued Member
    Uk
    I had a similar thought, but not to try and get a full gaming rig up. I've got the tow bar option on mine, which in theory has a 12v outlet designed to power a caravan when traveling, so run a fridge etc. While it's still no way going to allow 600W as even without finding any actual "fuse" ratings from Tesla the standard hook up wiring is only AWG13 and it's unlikely that they'd over engineer this. But I was wondering if I could power the caravan from the car while it's parked up, and therefore run the fridge, lighting, charge phones .. and maybe an oculus quest ;) also all external so no wires hanging out of windows and plugs designed to protect from rain.
    While the car can't tow the caravan as it's over 1ton and also the range would suck, maybe it could power it...
