Can you summon using the key fob
Discussion in 'Model X: User Interface' started by Merrill, Sep 29, 2017.
  1. Merrill
    Merrill Active Member
    Sonoma, California
    Wondering if my ap1 x will summon using the key fob and if so how do you do it.
  2. vandacca
    vandacca ReActive Member
    Hamilton
    See page 91 in the User Manual. Short answer "yes" and hold down the fob until the lights flash, then press the frunk to summons forward and trunk to summons backwards. Will work only if Summons is turned on in console settings.
    FOB summons doesn't work outside of Mexico & USA.
  3. KBurbridge14
    KBurbridge14 Member
    Placer County, California
    I can’t get it to work with the key fob. Any idea if there is a certain update required before this will work?
  4. MorrisonHiker
    MorrisonHiker S 90D 2018.26
    Colorado
    You need to have Require Continuous Press disabled in order to summon via the key fob or via the double-tap park method.
  5. gfb107
    gfb107 Member
    Cary, NC
    I had one fob that wouldn’t summon, and one that would. Went in to the Service Center, they tried a number of things including updating the fob firmware, but in the end they gave me a new fob. Kept the old one as a spare.
