Canadian CHAdeMO charging
Discussion in 'Canada' started by Doug_G, Jul 30, 2015.
Tags:
  1. Webeevdrivers
    Webeevdrivers Active Member
    Canada
    Sure. But in a grocery store parking lot speed is not your friend. A typical grocery run in 40 minutes for us. A 50 or 60 percent charge is totally adequate in that time frame. I personally wouldn't want to see it any faster than that. Otherwise you would be running back to move the car after half an hour because its full. .
    JMHO
  2. CanadaGoose
    CanadaGoose Member
    Ottawa, ON
    That's assuming we will even have ChaDeMo adapters that will go that fast or CCS adapters.
    We are capped at 50KW. It will take an hour to go from 20 to 90% likely.
  3. Webeevdrivers
    Canada
    Which for a Grocery store parking lot is just about right. Or a mall where its easy to drop an hour.
    The Chademo charger is a little clunky and heavy but its a god send in BC. Without it you very limited where you can travel. I hope the CCS adapter (if they actually release one some day) will be a little faster and a little less bulky than the Chademo. Meh. It works.
  4. MD-2000
    MD-2000 Member
    Winnipeg
    I recall there was a CCS adapter for older European Teslas (European CCS to Supercharger). Apparently there was also some additional physical hardware install required to make it work. I wonder how much change is needed for something like that to work with a Model 3, since the European ones are designed to work with their version of CCS? Could they at one point simply release a plug adaptor much like the J1772? I wonder if such a CCS setup would also be capped at 50kW or is that a limitation of the ChaDEMO adapter itself? Or ChaDEMO charger units?
  5. DMC-Orangeville
    DMC-Orangeville 85D and John Deere 5100E
    NW of the 6ix Canada
    There is a Korean CCS to Tesla adapter - for North American cars out there now. It's limited to 200 Amps - so about 70KW....but I'm not sure I'd trust it.
    CCS Adapter | SETEC POWER
    But it's coming.......
  6. Webeevdrivers
    Canada
    I still want to know more about the “USB FOR UPDATE” comment.
    But when the price comes down a couple hundred bucks we would probably roll the dice.
  7. mociaf9
    mociaf9 Active Member
    I'm sure it's to give you a means to update the firmware on the adapter.
  8. wws
    wws Member
    Northern California
    A few interesting new CHAdeMOs just showed up online on plugshare in BC - along Highway 97. Specifically Burns Lake, Prince George, and Groundbirch (near Chetwynd).
    I have no immediate need of these. But one of my 'bucket list' items is to someday drive the Al-Can. These new CHAdeMOs would certainly help. (I'm still amazed that there aren't any places in Fort Nelson listed on plugshare to even do L2 charging. Just a couple of RV parks with TT-30s.)
  9. Webeevdrivers
    Canada
    One of our planned trips is Prince Rupert. Which is now possible...but will be better when the rest of that string comes on line.
    Going to carry a spare tire on that route though.
  10. SlyWombat
    SlyWombat Member
    Mississauga, ON, CA
    Yeah, and I think the stress that will put on the socket will be too much, almost needs legs to rest on the car. But for $1000 CDN (discounted price), not gonna happen.
  11. Vawlkus
    Vawlkus Active Member
    Halifax
    Same can be said for the chademo adapter.
  12. Webeevdrivers
    Canada
    I don’t know. Looks smaller than the Chademo adapter. And lighter.
  13. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    Very interesting. I just sent the company an inquiry about shipping to North America.
  14. RiverBrick
    RiverBrick Active Member
    Mount Washington Valley
    There are photos on Plugshare showing construction in progress at the three sites closest to St. John's.
    There could be construction elsewhere, but where there's no Plugshare member available to post photos.
  15. RiverBrick
    Besides the government grant, the other source of money is IGA'S social responsibility/environmental budget. So, it should work in the sense that they are going in not expecting to turn a profit.
  16. Vawlkus
    Halifax
    EVAAC has a member looking forward them. He’s seen the actual hardware being delivered to a warehouse/receiving dock, but he hasn’t seen them being installed in the field yet.
  17. Tz00
    Tz00 3 LR AWD
    NB, Canada
    • Informative x 2
  18. Vawlkus
    Halifax
  19. CanadaGoose
    CanadaGoose Member
    Ottawa, ON
  20. Tectonic
    Tectonic Member
    Colorado
    • Informative x 3
