RiverBrick
The lower the battery is charged, the lower the voltage is when DC charging a Model S. When my 85 is nearly empty, the recharging voltage is only about 330V, but at Superchargers this is compensated for by massive current. However, with CHAdeMO we're currently stuck at 125A, so if you start at 0% SOC, at best you get 41kW from CHAdeMO. In my car, with constant current the voltage rises enough to get 47 kW at 76% SOC. Then voltage continues to rise, but the amps taper and the overall power drops exactly as it would at a Supercharger.
Unfortunately, more and more Circuit Electric CHAdeMO in Quebec are throttled to 103A-108A, so you can see as low as 33 kW.
Specifically, if traveling from Drummondville to the Altantic provinces, Gaspesie or the Bas St -Laurent, skip the now 103A Levis CHAdeMO and head straight to the 125A La Pocatiere one, if you can. (It would also help if the planned Levis and Riviere du Loup Superchargers arrive.)
