You almost got through that without making some kind of California political reference. Good effort.
It's sort of hard not to. My EVs run on grid electricity, and I run grid-tied. Summer rates were brutal, double demand fees, highest TOU rates, and a heat wave that went past 110°F several times. I need to temp control to 70°F ±2.0°F per gov't restrictions 24/7/365.
It was $.24 per kWh. OWW! $1900/m for 8000kWh. But virtually all is On Peak at the highest rate.
Right now it is the lowest rates of the year, a mild winter so far, no hot or cold days. 13kW (average peak) of solar output, and other energy saving technologies.
Because of this, I'm using 25% of the power I used last year, at the lowest possible rates, 2124kWh for $560. Or $.
26/kWh. Virtually all off-peak since the solar zeros out the TOU mid-peak usage.
The less power I use now, the higher my cost per kWh is. It is $229 a month for the NEM 2.0 meter, plus demand fees, plus other fees, and the electricity used is only $113 including both generation and distribution.
So far this month:
If I should plug in a 7.2 kW EVSE at work at 8 am tomorrow, the first 15 minutes is $114.41 (7.2kW x $15.89/kW) for the size of the charger and $0.50 per hour for the actual electricity used. Charging EVs is very cheap. You simply can't afford to pump the energy through the meter. Hahahaha...
Call it normal. Call it progress. Call it The Green Advantage. It still stings. It still hurts EV adoption.
HA!!! I did not mention the state or the P Word!
