Can't cruise above 90 mph?
MarcG
4,307
6,250
San Francisco
Anyone who has driven on I-5 in central California would know there are long boring streches of straight, flat freeway where speeding way above the limit is the norm.
So I was cruising along at 80 mph (about 130 kph) when a series of cars passed me going significantly faster.
As I had plenty of charge left to make it to the next supercharger, I figured "what the heck, let's see what this P85D can do".
In order to follow the train of cars at a safe distance, I decided to increase my normal following distance of 1 to 4, and tried to set the cruise to a high speed so the TACC would keep up with the fast cars in front.
To my great surprise, it unfortunately seems as though 90 mph (about 145 kph) is the maximum speed at which TACC can be set. Even if I set it at a lower speed and increase it manually, it will stop at 90 mph.
Maybe TACC cannot properly decelerate in an emergency if the car is going above 90 MPH based upon stopping distance vs following distance?
What if you set the following distance to 7?
That was my thought, too. But I'd be surprised if it calculates stopping distance for each following distance and has a different max TACC setting for each.
- - - Updated - - -
80? There are roads in the US with a posted speed limit of 85.
There is only part of ONE road in the US that has an 85 MPH speed limit -- 41 miles of SH 130 in Texas (a toll road).
I think that cruise control top speed makes sense for the U.S. It may well be higher for Euro spec cars.
I know I5 well. I normally keep to 75 in the right hand lane. Sometimes cars whiz past me on the left.
I have driven many tens, possibly several hundreds of thousand of miles through the rural highways of the western US and Canada, and agree that one prudently can drive at 90, and in places slightly above, along good amounts of these roads. I vehemently disagree, however, that that should be done with cruise control. When you're moving at one mile every forty seconds, or 132 feet every second - or faster - then the lag in reaction when your go-foot has not been firmly attached to the go-pedal is, I will insist, irresponsible driving.
The car can see more clearly and react faster than you can. The Delphi radar that I think it the most likely candidate for the Model S tracks everything out to 600 feet in front of the car within a twenty degree arc twenty times per second, with exact position and speed on all of it. I haven't found an exact answer for the Model S, but 100 mph to 0 stopping distances at full panic seem to be in the 350-400 foot range for most cars.
I'd hazard to say if it isn't safe for TACC to be driving at those speeds, it isn't safe for you to be, either. :)
Walter
umm. isn't stopping distance at 90 mph 600 feet? So if the tracker can only see 600 feet....then it limits to 90 mph?
edit: changed braking to stopping.
I don't know, for the Model S. However, I found a Car and Driver article about brake fade from a few years ago, in which they tested a bunch of cars from 100 mph to 0 over and over again. That's where the 350-400 feet I mentioned above came from. I really doubt the Model S had longer distances than all the compact cars and SUVs considering how short the 60 mph distance is.
Walter
Walter
Not trying to start a fight here, but the problem with that line of thought is assuming that the human can only see down 600 feet as well. My eyes are pretty good, and during my younger speeding (statute of limitations have long passed) days, I would look about a mile down the I-5 for signs of cops. 1 mile - 5230 feet. Pretty significant difference in awareness vs. reaction time. Wouldn't try that again at my age, but just pointing out that TACC seems to be inferior for some stretches of highway (namely long straight ones).
My guess is practicality. Tesla probably doesn't want to encourage high cruising speeds, because it'll drop the range down like a rock! No numbers available to back that up though.
