Can't Send Text With Voice Commands
Discussion in 'Model 3: User Interface' started by McQ14, Nov 3, 2020.
  1. McQ14
    McQ14 Member
    PA
    I'm sure this has to do with my new iPhone 12, but I can't figure out how to fix this issue.
    I am unable to send text messages from my Model 3, using voice commands. The phone is connected, it can play music fine through the car and make phone calls, but when I try to send a text I get the message shown, below:
    My Tesla app works fine with my phone, and I can't think of a reason it will give me this message. The frustrating part is that I can't expand the message to see all of it. It doesn't matter who I try to text, it won't work regardless.
    Both my phone and Tesla are absolutely updated with the most recent software, by the way.
    Any ideas? Anyone else running into this?
  2. Gasaraki
    Gasaraki Active Member
    Syracuse, NY
    Does the iPhone12 not have iOS 14? It does say it's not supported...
  3. McQ14
    McQ14 Member
    PA
    My phone has iOS 14.1. And the car is up to date as well.
  4. Haldorsonb
    Haldorsonb New Member
    Ontario, CAN
    I am having the same issue on my M3.
    iPhone X, and iOS 14.2. Not sure if it was happening on 14.1 as well but I cannot send any texts. tried everything so far.
    Must be a compatibility issue between iOS 14.1/2 and Tesla Software
  5. McQ14
    McQ14 Member
    PA
    I'm surprised more people haven't experienced this. I'm sure it'll get sorted out eventually but it's certainly unexpected and unusual.
  6. Knightshade
    Knightshade Well-Known Member
    NC
    I've a different issue (Iphone X, same issue with both ios 13 and 14)- I can receive texts most of the time (it does miss one once in a while) but when I try to reply it 100% acts like it worked, but 1/2-2/3rds of the time no text is actually sent back.... initiating a text (ie not as a reply) seems to also have a high failure rate- though again it ACTS like it worked, just when I check the phone no text was sent.
  7. McQ14
    McQ14 Member
    PA
    Yeah, that's similar, and also kind of strange. I wonder where the disconnect is in this issue?
  8. abianucci
    abianucci New Member
    Illinois
    I have the same issue - iPhone 12 Pro, Model 3 is current with software.
    It works if i repair the device for that trip only. Then any other time I enter the vehicle I can't reply to messages. I can send new and that's it.
  9. MXLRplus
    MXLRplus Active Member
    Eastvale, CA
    The reason you haven't heard a lot about the buggy cellphone integration is that we have come to expect poor software functionality.
  10. Knightshade
    NC
    FWIW mine has "improved" since I last reported.
    Now replies tell you they failed to send- which has been at a rate of about 100% when my wife texts me.
    So, at least you're told it didn't work now....(not why or anything, which might actually be useful... but hey... PROGRESS!)
  11. elptxjc
    elptxjc Member
    El Paso, TX
    Where is the detailed info how to text from the car via voice commands? Don't remember seeing that in the manual. I'd probably never use it, but would like to know how to, just in case. Thx.
  12. Knightshade
    NC
    Page 138 of the current manual describes texting
    Voice command overview here:
    Voice Commands
  13. elptxjc
    elptxjc Member
    El Paso, TX
    Thank you very much. Will give it a shot next time I use the car. We couldn't get any music commands to work, but apparently you need to do it in steps, like 'open music', or 'play' first, then I guess will ask for which source to play, and so on.
  14. EduardoNJ
    EduardoNJ New Member
    New Jersey
    Same issue here. Model Y 2021, iPhone 12 Pro Max, iOS 14.3. I can received messages no problem at all, but every time I reply, I get a little 'Send failed' in red in the bottom left of the UI. Fails 100% of the time. It's rather annoying.
  15. Marty3SR+
    Marty3SR+ Member
    Pleasant Hill, CA
    Considering how important software is for this car, that's a bit scary. :-(
  16. N.Y.R.
    N.Y.R. Member
    Calgary
    Have never got this to work since day 1. Can get texts, can’t reply.
  17. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    Same, but a 2018 Model 3.
  18. Cybr.Myk
    Cybr.Myk Member
    Saskatoon
    mine will reply perfect every time but I have trouble initiating a new text convo. It always seems to get the wrong name.
  19. Bubbatech
    Bubbatech Member
    Alabama
    Some may be unaware that messaging must be enabled in the Bluetooth settings in order to receive and reply text messages. I have also found that after updates this feature sometimes gets turned off. You get to the Bluetooth menu by tapping the Bluetooth symbol on the screen.
  20. N.Y.R.
    N.Y.R. Member
    Calgary
    I've got everything set up, set up the Bluetooth notification settings on my iPhone under the bluetooth options, everything. Just doesn't work.
