Capped regen even at below 90%
Discussion in 'Model S: Battery & Charging' started by metafor, Dec 10, 2013.
  1. metafor
    metafor Member
    Portland, OR
    So it's getting colder in the bay area these days and perhaps that's the reason but I've noticed lately that my regen is capped at ~30kW or so nowadays (seems inconsistent) at various battery charge levels. Previously, it'd only be capped if I was at 100% or close -- which made sense, you can't charge a battery at 100%.
    Now, I've gotten it at 50%, 90%, 80%, etc. I try to use the regen brakes almost all the time in order to reduce wear on the brakes as well as maximize energy efficiency. So this is particularly annoying for me. Is this an effect of the colder weather? v5.8 software? Both?
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    It's the cold weather we've had for the past two weeks. A bit unusual for early December in this area but not unheard of.
  3. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    When I get a Model X this will be a big and strange change for me. My Volt does normal regen at any SOC (i.e. morning at 100%(aka 87%)) and seemingly any temp as it worked last night at 3F.
  4. ecarfan
    San Mateo, CA
    How can a Volt provide regen at 100% SOC?
  5. darthvdr
    darthvdr Member
    los gatos, ca
    The cold definitely zapped efficiency from our MS. It was getting into the low 30s last night and as I was driving home we were getting into the 450Whs even while driving just 40mph. I pre-heated the car for 30 minutes prior to driving as well.
  6. strider
    strider Active Member
    NE Oklahoma
    Just set your charge timer to start later so it will finish charging closer to when you plan to leave*. That will have the battery warmed up and regen will work as normal.
    *I wish Tesla would give us "departure-time" charge scheduling to make this simpler. The RAV-4 has it and it's a Tesla drive train/electronics so it must be possible.
    - - - Updated - - -
    He means 100% in what we would call "standard mode", hence the "aka87%"
  7. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    double check that you are not in low regen mode.. I forgot I had set it to low once during a snow storm.
  8. voidptr
    voidptr Member
    Apex, NC
    My experience seems to show a crossing point where as the temperature drops, the Wh/mi goes up as you drive slower. The energy draw apart from the drive train to warm the car goes up is constant in time, not distance, and it becomes significant the colder it is. If you're doing highway speeds, the pack does a better job of keeping itself warm, while the heater's only switched on for 60s/mile instead of 90s or 120s/mile.
  9. metafor
    metafor Member
    Portland, OR
    Interesting, I guess I never experienced cold weather with my S before, but I've never seen this happen prior to 5.8...
  10. cinergi
    cinergi Active Member
    MA
    Both. 5.8 (or 5.6, perhaps 5.0) is more aggressive with limiting regen when it's colder. I've had regen limitation showing when it's as high as 50F outside. Last winter it had to be more like 40F.
  11. stopcrazypp
    stopcrazypp Well-Known Member
    Isn't the cold regen limit orthogonal to SOC (as in it depends on the temperature, not the SOC)?
    I would also like to point out the Bay Area has seen record cold temperatures in the last couple of days.
  12. GDH
    GDH Banned
    Portland, OR
    My regen was completely disabled this weekend when it was in the teens and boy did that suck having to use the brakes constantly.
  13. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    I saw regen limitation below 100% SOC for the first time a few weeks ago when we got to the low 50's as well.
  14. rlang59
    rlang59 Member
    US
    Yeah I started noticing the regen limit when it started to be in the 50s.
  15. scottf200
    Correct. As well I think they use the two motors (without ICE on!) in this way as described by a GM person (on gm-volt)
    Again when I get a Model X this will be a big and strange change for me.
  16. strider
    NE Oklahoma
    Ah, never knew that about the Volt. Thanks for posting!
