sorka
1. Tesla and ICE quarter miles times simply cannot be compared with respect to horsepower. You don't need nearly this much power to achieve even lower quarter mile times if you have an ideal transmission, which is nearly what you're getting in the Tesla.
2. The corvette does not "have 644 hp" at altitude. It only has 644 hp at SAE standard temp/pressure/humidity.
Still waiting to see what MT did. They usually publish a sheet with all their numbers and correction factors, I've seen it before for other cars.
- - - Updated - - -
Because the tires suck.
Yes, and no. You can still compare exit speeds with eventual maximum held horsepower, but the Tesla puts out more power under the curve (and hence more torque at each RPM at that point as well) than a typical ICE at lower RPMs so the Tesla gets the hole-shot advantage. Once the ICE is up to it's maximum horsepower and is straddling that with it's 8 speed multi speed transmission keeping the power at near peak (which again puts out maximum torque at the wheels for each RPM) they become more compatible. At that point, the 532 L (at > 90%) accelerates just as hard hp / lb as any ICE with a slight advantage going to the Tesla because the ICE can't hold peak power. The ICE that makes 550 hp peak is only making 525 (example) average peak between the shift points......except that the ICE has more drivetrain losses in 1st than 4th so less of the 525 peak average makes it to the wheels.
So you can compare them, as long as you compare there differences. The EV has an ultra wide power band which allows it to put down more power at early RPMs compared to an ICE and hence more torque.
The EV doesn't lose power at altitude. But loses power on cold mornings unless your battery is warm.
The EV loses power as the battery SOC goes down if it was already maxing out current at maximum charge (p85D(L)(90D)(L) variants.
Each has their strengths and weakness. I will say that all things roughly equal a 500 hp AWD EV car is faster in all respects to a 500 hp AWD ICE as it makes wider power and more of the power it does make at any RPM is sent to the wheels.
