bradtem
Robocar consultant
Many companies make a TT-30 to 14-50 adapter for EV charging. It is different from the standard adapter sold to owners of 50 amp RVs, which will not work for EV charging. This one puts the 120v hot and neutral to the two hots of 14-50. Don't mix them up! However, as noted, if you do this you must be absolutely sure that you have dialed your car down to use only 24 amps before you start charging, as your car will draw up to 40 (or 32 on a non-long-range) via the 14-50. If you fail to do this you will blow the breaker and possibly other not good things.
Tesla could make this safer by just saying "If I have 120v, I should default to 24 amps because there is no circuit with 120v at more than 30a." Somebody claimed they do this, but they don't last time I tried.
The 3rd party adapter is another choice, it is around $70. It doesn't exist, but if somebody made an adapter for TT-30 to one of the Tesla official 30a plugs (like dryer plugs) that would also be a good choice, but I don't think anybody makes it.
The 3rd party adapter is the safest available choice, but the reality is you are not going to charge on TT-30 very often because it's really a "last resort" sort of thing. You will only pick up about 100 miles overnight, which is much better than nothing or the 50 or 70 miles of 15a/20a, but it's still not the nice benefit of stopping overnight at an RV park for a complete fillup as you get from 50a.
I've used mine only twice, at motels that had RV hookups behind them. The first one the hookup was dead, the second worked. Because I was there 2 days, it made it worth it, but it's the only time in a large number of charging stops.
If you drive a lot in rural areas where 50a RV spots are not found, it is a different story, but don't expect that to be easy. Such areas usually also don't have fast charging, at least yet.
