I've known my cars to have temporary problems with moisture between the window and the car door -- as if the seal isn't working well -- after I roll down the window after it rains or after a car wash. This results in the unsightly streak of moisture on the window when you roll it back up. However, the problem typically goes away in a day or so. My car has had this moisture issue and streaking for almost a week now, and the car is parked in a garage at home and at work. Does anyone else have this problem? I am wondering if the seals are in need of a check.
