Car heating up when parked upwards of 90 degrees farenheit
VQTRVA
451
476
CVA
I noticed this too last week on my wife's 3 as her black/black sits in the open air during the day.
got up to as high as 104 last week on a 55 degree day.
We have 35% Llumar Pinnacle tint all around with a windshield sunshade & no tint on the roof & rear window - last week.
We tinted the roof & rear window this weekend & it appears to have help some as current interior temp near noon in Sunny 41* is 72*.
Will monitor this event....
jat255
93
78
Boulder, CO
App currently shows my interior at 89f. It's overcast and ~35f outside. Doesn't seem right to me.
I'd agree, that's weird. Here's what mine looks like over the past ~two hours sitting in the sun. It's just a little over 40 degrees F here. For the sake of debugging, this is on 2019.5.15, and sentry mode is currently on (climate is off; I believe overheat protection is on)
brobinson
621
637
Ohio
15 minutes later, and its up to 91f. The sun broke through the clouds for a bit, but its still way higher then it should be. I'll have to check to see if I have overheat protection on. I think I had it set to 'fan only' but its been a while since I looked.
I do also have sentry on and the app shows that climate is turned off. I'm not seeing battery drain anywhere near the level I would expect if the climate was running all the time, so I do wonder if its a case of it cycling on and off periodically for some reason.
novox77
1.21 Gigawatts
Nov 25, 2017
1,632
3,532
NH, MA
still haven't seen anything here that makes me think it's something outside of normal greenhouse effect. I picked up my car this time last year and also witnessed huge temperature deltas between outside ambient and cabin. It gets more pronounced once ambient temps are above 40F.
Last friday I parked outside but stayed in the car. It was 50F outside. Within 2 minutes, it was uncomfortably hot inside. No HVAC needed to generate that heat.
Reactions: mswlogo and VQTRVA
dkde
31
Bethesda, md
It’s 42 out and my car is nearly 100. Since
to quote Tesla support “I reviewed the diagnosis performed by both the Service Center as well as our Advanced Vehicle Support team. Both parties determined that the commands were indeed coming from the mobile app.”
It is 42 outside right now and my car is reading Nell’s temperature of 96.
jat255
93
78
Boulder, CO
Small update:
Two hours after I parked, and the temperature jumped up by 5 degrees almost instantly:
I could see how that behavior, combined with greenhouse effect over the course of a 6-8 hours could get the temperature significantly higher than you'd expect from ambient...
I think it's most likely a bug of some sort, plus typical heating from solar energy coming through. Without this sort of continuous tracking, it's hard to determine which.
Someone else having this problem, try setting an alarm for 2 hours after you parked and watching the app to see if you see the same behavior? I'll watch the app at 2:42 to see if I can see anything happen in the app.
Interestingly, that graph is supposed show show fan speed (if it's set), so the fact that it's not showing it means that the API is not registering that the fan is running. Not sure where the temperature increase is coming from.
Reactions: VQTRVA
dkde
31
Bethesda, md
Small update:
Yes. It’s interesting. Tesla is saying that my heat is being triggered by the app but if you go into the app climate control is off... I’ll try to figure out the scraper later to see if I can identify what behavior is actually happening. It seems that there is some sort of a bug. I mean I expect some increase in temp due to sun, this seems excessive.
SMAlset
8,732
9,338
SF Bay Area
I'll add most electronics are rated to operate up to 80C (176F), storage up 120C (248F).
Well for a Blackvue DR900S-2ch, the Operating Temperature is -20C to 70C (-4F to 158F) and Storage Temperature is rated the same. Their High Temperature Cut-Off is apx. 75C (167F). In comparision, the Thinkware 770 has a Operating Temperature of -10C to 60C (14F to 140F) and Storage Temp of -20C to 70C (-4 to 158F).
The Model 3 manual doesn't list any temperature rating ranges but there are numerous temperature limitations mentioned on for example Autopilot components, causing them to be unable to function as intended. These include (but not limited to):....Extremely hot or cold temperatures. Parking Sensors are mentioned under Autopark Limitations for: Weather conditions (heavy rain snow, fog or extremely hot or cold temperatures), interfering with sensor operation. Summons, same thing with sensor operation.
Now a Sandisk Extreme Pro microSD card is listed for Operating Temperatures of -25C to 85C (-13F to 185F) with Storage Temps at -40C to 85C (-40F to 185F). But if your dashcam has shut down before that won't help.
KG2V
195
151
Bayside, NY
Welcome to driving a rolling greenhouse. It is currently 43 degs outside, and my car is 89. Was higher a bit ago, but the sun was shining right on the car then
jat255
93
78
Boulder, CO
There's definitely at least something else going on here:
This most recent time, the temperature jump was only about 3 degrees, but still, that's 10 degrees of heating on top of the normal "greenhouse" heating that you can see from the steady progression upwards in the graph. I watched the app during this period, and nothing out of the ordinary showed up on the "climate" page (no indication anything was turned on).
To those saying this is just heat from the sun, how do you explain regular jumps in temperature every 2 hours on the dot?
dkde
31
Bethesda, md
And Tesla has states that they can confirm that my app is sending a signal to my car. now why it is doing so, that’s the question.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
Could it be the software that you are using (lephisto/tesla-apiscraper) to monitor things is actually causing the problem and sending the rogue request?
Need
2,863
2,178
SoCal
Or it could be the spouse! Some people think it is fun to mess with their spouse's Tesla music/climate/seat heater remotely.... not naming any names... :cool:
VQTRVA
451
476
CVA
Right before lunch today, i checked my wife's car on the app & the temps started rising exactly like jat255's graphs.
Currently, it's 48F & 100F inside the car!
My app says HVAC is not turned on.
She has sunshade up.
Argggg
mswlogo
5,965
4,572
MA, NH
Seems perfectly normal to me.
Currently 42F out and interior is 105F. It's not draining battery either and I have BOTH Tesla sunshades !!
March/April sun can be really strong. My Solar is going like gang busters, it loves this weather (cool air, beaming sun) !!
My Windshield is facing south. I've purposely parked it that way to warm the car as much as possible in Winter.
Time to install Windshield SunShade or move to my Summer Parking Spot (or both eventually).
Reactions: VQTRVA
novox77
1.21 Gigawatts
Nov 25, 2017
1,632
3,532
NH, MA
i would uninstall the app and then monitor for those 2-hour spikes in temp. If the app is indeed making rogue API calls for no apparent reason, seems like everyone on that version of the app should be seeing those spikes.
Reactions: is2scooby
