Car idling for hours at home/work before sleep
RealEvil_UK
102
28
UK
Hi,
Using Teslafi. Sentry mode not active at home or work. No summon.
Teslafi shows car idling for 2 - 3 hours before sleep. I can see from the raw data that Teslafi seems to be sending sleep commands but car won’t sleep for ages. I think my Teslafi sleep options are normal - and it is trying to sleep the car it seems.
It doesn’t seem to be related to a software update etc and it’s happened daily, twice a day for days now.
Anyone have any ideas? I am losing 1-2 miles range every time. In a SR+ that’s problematic!
Happy to post raw log entries if that will help?
VanillaAir_UK
6,936
4,478
Surrey, UK
I was looking into this for another user, but thats all gone off the boil. However, my observations during that time were:
Probably once per day, some extended communication seems to take place between car and somewhere. During this period, car remains idle. For us, it seems to occur immediately after the drive from home each evening. Seems to consume just over 0.5kWh in energy.
If communicating over wifi, this period seems to last longer (>2hr) than when on mobile (<2hr). I've not bothered to sniff the data yet, so not sure if difference in time is because wifi is slower, or more data is being transferred hence taking longer.
Lots of theories what this data actually is.
Sorry to say, but sounds like if 1-2 mile range loss is a problem rather than just an inconvenience, you probably would have been better off with the longer range car. Range is everything.
Reactions: Roy W.
NorfolkMustard
2,106
2,017
M3P w/FSD
Rather than telling it to sleep, all teslafi is able to do is give it some time to sleep of its own accord. Usually teslafi tries this by leaving the car for 15 minutes and not asking the car how it feels every 60 seconds in those 15 minutes. After the 15 minutes is up teslafi then asks Tesla HQ (not the car) if your car is asleep or not.
Do you have any other services you've given your tesla credentials to which could be keeping it awake? or are you (or anyone else) opening the tesla app during this time?
Reactions: Rooster6655
RealEvil_UK
102
28
UK
I did briefly setup "Dashboard for Tesla" on Android but I logged out and deleted app (it doesn't have a server component apparently). I will change my Tesla password now but I doubt this is the issue.
Thanks for the info on Teslafi - its language is confusing. It talks about "trying to sleep" (suggesting a positive action) but yes on deeper inspection, its just pausing polling. Interesting.
Rooster6655
1,513
521
UK
Hi,
If you leave the car alone it will stay idle for up to 4 hrs every 28 hours, if you drive the car this idle time is often reduced.
During idle time the amount of mileage used is based on the temperature outside, I tested this for weeks and have the teslafi data.
WannabeOwner
5,758
2,893
Suffolk, UK
I would:
Change password in My Tesla
Turn off all possible background power uses (Sentry mode, Smart preconditioning, Cabin Overheat Protection etc.)
Only re-activate password on TeslaFi. Set appropriate locations to Sleep / Deep Sleep (i.e. in TeslaFi). Disable any scheduled events in TeslaFi
Wait 24 / 48 hours to see how TeslaFi records sleep, and if range-loss becomes acceptable
Re-enable other APP(s) that you use. If range loss becomes unacceptable give up on that APP
Compuguide
87
98
London
There is some discussion about this topic in the this thread.
I have found that disabling wifi when at home (I have a TP-Link Nano wifi extender in the garage) enables the car to go to sleep much more quickly
Christiez
237
137
Lincoln
My car has been idling for 16 hours straight, have disconnected wifi, stopped data sharing, switched bluetooth off (phone), gone through Teslafi settings..anything else I can try?
DJP31
1,640
1,032
UK
I think your car is behaving normally, but there is no doubt compared to a few months ago, the car is idling for much longer than it ever used to. Whether that’s by design or some sort of bug I’ve no idea, knowing Tesla it could easily be either!
Your TeslaFi settings are normal. One thing I have noticed with the sleep attempts that don’t work, if you start a journey during one TeslaFi wouldn’t pick up the data until it start polling again. E.G yesterday I did a 5 mile journey with an average speed of 30mph and TeslaFi said the journey took 5 minutes :rolleyes:. When I looked at the map of the journey TeslaFi only started polling when I was halfway there.
NorfolkMustard
2,106
2,017
M3P w/FSD
First question - how do you know? Most ways of finding out if the car is asleep, will themselves keep the car awake :)
things to try:
Have you gone through the checklist here My vehicle is not sleeping! / Knowledge base / TeslaFi
some of the more obscure ones:
Cabin Overheat protection (disable)
Sentry mode (disable)
tesla.com account (change password to disable all third-party api access
Reactions: Christiez
Christiez
237
137
Lincoln
things to try:
Cheers for the feedback, totally get what you're saying as checking on the state of the car is likely to wake.
I guess my concern is, nothing that I'm aware of has changed and car would usually sleep within an hour or 2 at most. Only a couple of weeks ago I left the car for 5 days and lost 4% but yesterday I lost 9% which is concerning.
I'll have a good look through at the Teslafi link to make sure I've not missed anything.
Christiez
237
137
Lincoln
As if by magic, Teslafi has reported the car as sleeping. No idea what changed between now and 17 hours ago to make it go to sleep. I guess being awake for that long makes you tired..
Jason71
2,341
2,069
Shropshire
things to try:
actually calling the GET https://owner-api.teslamotors.com/api/1/vehicles/{id} end point will tell you if it's online or sleeping but will not actually wake it up or stop it from sleeping so you can safely find out if its awake or asleep.
