Car keeps telling me to “Add a Wi-Fi Connection”
Discussion in 'Model S: User Interface' started by Stuart, May 7, 2014.
  1. Stuart
    Stuart Roadster#326, ModelS#1409
    San Jose, CA
    Every time I get in my Model S in the morning, it displays a message telling me to “Add a Wi-Fi Connection”, despite the fact that it already has a perfectly good Wi-Fi Connection showing four bars of signal strength. No matter how many times I press the “Connect to Wi-Fi” button, delete and re-add the Wi-Fi Connection, etc., every day it still tells me to “Add a Wi-Fi Connection”.
    Have other people seen this?
  2. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    We didn't for a long time; but last week we saw it a couple of times.
  3. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Mine did this. It started when I deleted the original WiFi connection I added when the car was new, even though there were other connections.
    As you've found, simply removing and re-adding them didn't work. Seems ridiculous, but that's also what I found.
    What DID work was completely removing all the connections, and adding a new one that's different from the all previous ones. Something the car has never connected to before. I temporarily changed my phone's hotspot name to "DO NOT REMOVE" and added it as a new connection. Then I changed the hotspot name (on my phone) back to what I actually wanted and added that connection as well. Now I have a reminder that if I remove that "DO NOT REMOVE" connection I'm in for a cranky vehicle.
  4. nikwest
    nikwest Member
    Munich, Germany
    I reported this behaviour to Tesla. The feedback I got was that once you connect it to a stationary wifi the message should go away. It does not go away if you connect it to a shared connection from a mobile phone or mobile hot spot.
    As I don't have a stationary wifi available I can't get rid of the message panel. Pretty annoying.
  5. jayman
    jayman Member
    Illinois
    I'm getting it too just about every am and it's while it is connected to my home network. Definitely a bug...
  6. swegman
    swegman Active Member
    I was told today that Tesla is aware of this issue, and that a future s/w update will include the option of indicating not to ask the question again. I did not get this message until my car was updated to ver 5.9. Now I get the message everyday in my garage, and when I pull into certain shopping centers that I frequent and which apparently have wifi service in the parking lots.
  7. Thumper
    Thumper Active Member
    Portland, OR
    swegman +1
  8. Gizmotoy
    Bay Area, CA
    There's no way for the car to differentiate between an access point that's moving and one that's stationary unless they check the GPS. Either way, this can't be true, given the process I followed to eliminate the nag screen (noted above). Sometimes I wish Tesla would just say "I don't know" rather than telling customers the wrong stuff.
  9. nikwest
    nikwest Member
    Munich, Germany
    Well, I guess this could always determined by checking IP addresses originating from mobile networks.
  10. PhilBa
    PhilBa Active Member
    Seattle
    I get this just about every time I park the car. There is wifi everywhere I go, it seems. Yesterday I got it at home, then at the mall, then Target, at home again and then the Food Store. I have actually set it up for home but the connection is too weak in the garage so it never actually connects. It also sees my neighbors unprotected wifi since my garage is close to where they have their router. (Yes, I've offered to help them put a password on it.)
  11. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    A reboot of the center screen cleared this up for me.
  12. SeattleSid
    SeattleSid Member
    Pacific Northwest
    I look forward to if/when an update offers the "don't ask again" option. I get the message every morning. Compared to other things in life, it's a very minor annoyance, but still...
    My problem is that my home wifi isn't very powerful in the garage. The car detects it, but when I try to "join" the network it spins and spins and finally says "unable to connect." Fine. Not an issue. But then, every morning, it wants to go through it all again. The only reason to have wifi in the car at home is for the updates, but they work fine on 3G. I found I could have a strong signal in the garage by putting a "booster" there, but didn't see a reason to keep it plugged in for the occasional firmware update. So, far as I can tell, there's no solution until/unless there's a firmware update that addresses it. Here's hoping.
  13. Dukecat
    Dukecat Member
    Carefree, AZ
    This issue just came up for me within the last week or so. Rebooting didn't help, but deleting my home network and then adding it again did the trick.
  14. Gizmotoy
    Bay Area, CA
    There are options. If your phone has a hotspot mode you can do what I posted earlier in the thread. Otherwise drive to a Starbucks or McDonald's parking lot (or any other place with free WiFi) and connect to their WiFi.
    Annoying, yes, but will eliminate the probably for you until Tesla has a real fix.
  15. Doug Gallarda
    Doug Gallarda P03915
    Austin, TX
    I had the same problem. My service center explained that this happens when you connect to a mobile hotspot in "tether mode." You can see that you're in tether mode on your iPhone or iPad when you get two chain links instead of a wifi icon after connecting.
    I had both my home wifi and mobile hotspot configured, but kept getting the nag screen until I told my car to "forget" the iPad hotspot.
  16. Gizmotoy
    Bay Area, CA
    Some clarification from Tesla on this would be nice. I have two WiFi hotspots added to my Model S. Both are in "Tether Mode." No nag screen. Indeed, the car nagged me repeatedly UNTIL I connected to the tethered phone, and once I did it stopped.
  17. eelton
    eelton Member
    Chicago, IL
    I get this every morning. I've never tethered, and the car is set up to connect to my home wifi. Perhaps the problem is that I live in a condo, and the car picks up maybe 10 different wifi networks from other units (or nearby buildings).
