is this user error? I park my car in the garage and leave. I will come back at times where the motor sounds like it’s running but the dash is turned off. I will turn the car on and off but come back later and it’s doing it again. Is this normal?
Yes, it’s normal. It’s not the motor, which only runs when the car is moving, but rather fans and/or the AC compressor cooling the battery. It’s more likely to happen as you’re charging, but it can happen at other times as well.
Also noted your location... if you have Auto Overtemp protection on, it could be cooling the car from that. Check the temperature inside the car from one of the apps and see how hot it may be getting.
