Car kicks up dust and dirt on rear: Any solutions?
Discussion in 'Model 3' started by f308gt4, Jan 24, 2021.
  1. f308gt4
    f308gt4 Member
    SoCal
    I know, first world problem...
    I do like to keep my M3P clean though, and I’ve noticed that the rear gets really dusty/dirty pretty quickly, while the rest of the car stays relatively clean. I’m pretty sure it’s related to the aerodynamics of the car.
    Are there any solutions? Mudflaps? Rear diffuser? Or do I just have to keep wiping it down after each drive?
  2. MXLRplus
    MXLRplus Active Member
    Eastvale, CA
    It's true for all modern cars. Mudflaps can help.
    Your car is a vacuum. It sucks the dirt off the ground it passes over. A diffuser makes it worse, not better.
    • Informative x 2
  3. f308gt4
    f308gt4 Member
    SoCal
    Thanks, that’s what I suspected. I did have the same issue with my 911. I wish there was something you could do to help reduce the dust.
  4. VeryRealPerson
    Vancouver BC
    Decontaminate, seal, and consistent protection. Once you do the big one, its quick maintenance washes with ONR for like 9 months before you have to do the whole process once again.
    You do the beginning step so your maintenance washes are quick and effective.
  5. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    raise shields.
    • Funny x 5
  6. boiler81
    boiler81 Member
    Manson, WA
    Yeah but that drains the battery too fast;)
    • Funny x 5
  7. SabrToothSqrl
    PA
    always a catch.
  8. Candleflame
    Candleflame Active Member
    QLD, Australia
    i have mudflaps. not sure if they make a difference. my car also likes to get dirt on the rear though.
  9. XLR82XS
    XLR82XS D M C
    SWFL | Vegas
    That's what I do. Ceramic-infused wax and Griot's BOS liquid detailer in between washes. It's inevitable the rear of cars will get build-up due to aerodynamics. Best you can do is touch-ups when possible.
    If PPF is applied to the trunk lid, bumper & tail lights that will help avoid rail dust and the like from sticking to the paint. Also eliminates paint scratches when waterless washing.
  10. chewychiu
    chewychiu Member
    Long Island, NY
    I like to detail my own cars right after delivery. It makes it a lot easier to wash everything off your car as you feel the mitt glide very smoothly across the paint. Not sure if that helps...
  11. mswlogo
    mswlogo Well-Known Member
    MA, NH
    Get midnight silver so it hides it more.
    My wife’s white Volt is always filthy in the back. My MSM X doesn’t look nearly as bad.
  12. PDB2655
    PDB2655 Supporting Member
    Stuart,Fl
    I have madflaps they work well for me just have to keep the car clean just like any other vehicle. Teslas do get dirty then others its just part of regular maintenance of owning any vehicle
  13. SabrToothSqrl
    PA
    I used to be completely obsessive about keeping my car in perfect condition scratch free clean and all everything that goes with it. I would always be ridiculously paranoid parking anywhere or leaving it outside even while running an errand or having dinner. Looking forward to the cyber truck that should have century mode and be damn near unbreakable. Hit it with a brillow pad if it gets a 'scratch' i guess. lol
  14. Dadawinsk
    Dadawinsk Member
    Gloucester, UK
    Try to only drive on clean roads.
    NOTE: This may result in reduced annual mileage and a lower insurance premium as well!
    • Funny x 2
  15. freeAgent
    freeAgent Member
    SoCal
    You can use something like a California Duster to quickly remove light dust. That's probably the quickest solution. They're easier than using a towel and probably less prone to scratching the paint.
    • Disagree x 1
  16. camalaio
    camalaio Active Member
    Vernon, BC, Canada
    I somewhat admire you folks who feel the need to wipe down their car after every drive. In SoCal, where I presume there's hardly any dirt on the road to begin with!
    And here I thought I was treating ours nice when I gave it weekly washes!
    You may find it beneficial to listen to those folks who recommend a surface finish that makes it really easy to clean the car (e.g. those fancy ceramic coatings or whatever). It won't necessarily make less stuff stick, but might make your daily wipe down easier or less scratchy.
  17. VeryRealPerson
    Vancouver BC
    Big tip on the california duster. Make sure you use it properly or you will affect the surface.
    The product is supposed to be used with the tips just barely touching the surface of the car.
    If you use it like Arnold, the surface will have micro scratches/swirls.
    Just for absolute clarity... You need to use it like this picture
    • Funny x 3
  18. TORQU3
    TORQU3 Member
    MA
    Drive in reverse? :)
    • Funny x 2
  19. f308gt4
    f308gt4 Member
    SoCal
    Yes, I am using the California duster. It is quick, but I need to do it after every drive.
    My car is ceramic coated- doesn’t make a difference. Dust still has to be wiped off the rear after every drive.
    I was hoping there might be a better solution, but, as I thought, it doesn’t look like there is.
  20. freeAgent
    freeAgent Member
    SoCal
    Nope, unfortunately ceramic coating doesn't really help with dust. On the subject of coatings and such, I found that quick detailers seem (to me, at least) to make dust stick to the car more easily (my guess is because they grab the dust). That could be my imagination, though. The California Duster is the best solution I've found if you want to get dust off quickly without washing.
