Car lift for the house
Discussion in 'Model S' started by UMD86, Dec 8, 2012.
Tags:
  1. UMD86
    UMD86 Member
    Does anyone have a car lift at their home? I was thinking about getting one for my garage to swap out the 21" for the 19". I will use the 21" for summer and 19's for the winter. I don't want to pay for storage and change over every year. Also if I have a blowout /flat tire I'll be able to make the change at home.
    Was wondering on the cost and brand of lift. It would be a low rise lift - nothing extreme.
    TIA
  2. stephenpace
    stephenpace VIN S00219
    Houston, TX
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
  4. RDoc
    RDoc S85D
    Boston North Shore
    If you don't already have one, a compressor and pneumatic wrench are really helpful.
  5. dave
    dave Member
    Greater Cincinnati
    I've been swapping winter tires on my Infiniti for a couple years. I just drive with the TPMS light on during the winter and make sure to check the pressure manually every now and then. I plan on doing the same with my S, since the nearest service center is so far away.
  6. jerry33
    Texas
    That has worked for me for as long as I've been driving. (Never had a car with a TPMS--seems redundant because the energy usage shown on the screen is a great indication that your tires are getting low. It takes only a couple of psi down to show up in the energy use once you are familiar with the usage pattern of your car.)
  7. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I'm sure you're right about 2T being enough but the Rangers have been told by engineering that the jack should be 3.5T or above (that's what they told me at least when I asked what kind of jack I needed for the Model S).
  8. jerry33
    Texas
    My guess here is that the engineers are assuming folks will purchase the cheapest possible jack and get one with questionable quality. While I don't expect anyone on this forum to do cheap-out when purchasing a jack, I expect other folks to do just that.
  9. dsm363
    Nevada
    I bet you are right. I think the Rangers are required to use a jack at 3.5T though too so maybe that's just being extra cautious.
  10. jerry33
    Texas
    You can't be too careful when considering employee safety. They are doing this many times a day so the opportunity for injury is higher.
  11. Doug_G
    Ottawa, Canada
    You should see the enormous Jack (capital J) that the Rangers lug around with them. I suspect lifting the thing may be more dangerous than using it.
    To be fair the Rangers work under the car a lot, and I can see why they might want an extra margin of safety.
  12. tezco
    tezco Sig P85
    Colorado
    Our local service manager said that the Roadster model doesn't work on the S.
  13. shokunin
    shokunin P85 & M3
    Irvine, CA
    Anybody have any recommendations on worthy floor jack? Even when I'm not being "cheap" on a jack, they all seem craptastic and all seem to blow after a year or two, whether you use them a lot or a little. I've had $250 OTC Aluminum jack, Sears crapsman 3 ton racing jacks, cheap-on harbor freight jacks, a Torin jack and they all seem the same (crappy). The OTC jack I used twice and then a year went by, tried to lift my car and seals broke and hydraulic oil was leaking. Oddly enough the jack that has stood up the test of time is an old no-name 5-ton bottle jack.
  14. dsm363
    Nevada
    My Ranger today used a steel Matco Tools 3 1/2 ton jack called 'The Beast' today. Said it weighs a ton itself but very heavy duty.
  15. FlasherZ
    I've had the same problems. My Craftsman was probably one of the worst.
    I've settled on this one: Powerzone Jack and it works great -- 6 pumps to full height, solid handle, doesn't slam the jack down when you slowly open the valve, etc.
