Hi all, is it normal for the model y to make fan like battery thermal management noises when charging up via slow 12Amp 120 Volt outlet and When the weather is a constant cool 48 degrees F? Car had been charging up for about 7 hours. I was charging from 30% to 55%. I had preconditioning turned off. I’ve had the car 2 weeks and this is the first time I have noticed possible thermal management noises due to charging in such forgiving conditions. My volt only made such noises if it was very hot outside while charging or the battery was very cold when plugging in. I could understand hearing such noises if I were charging up at 220V with high amp or supercharger.
