Car no longer waking up from the app/API
Discussion in 'Model S' started by StefanSarzio, Jul 31, 2017.
Tags:
  1. StefanSarzio
    StefanSarzio Member
    Herford, Germany
    Some people in Germany (including me) have the problem that the car is no longer waking up from the sleep state. (Energy saving ON, always connected OFF). This is for about two weeks and not related to firmware updates.
    Anyone else outside from Germany having this problem?
  2. Nidem
    Nidem New Member
    Etterbeek
    Same issue here, I'm locaties in Belgium. I recentst got My car and I'm not sure If this is a setting or not...
    A few weeks ago it worked fine.
  3. widodh
    widodh Model S 85kWh
    Middelburg, The Netherlands
    Happening here as well in NL, same problem. I got a update last night to 2018.X and I hope this fixes it.
    Has been working before without any problems for me.
  4. culverwood
    culverwood Member
    Herts
    I have had the same problem recently.
  5. Nidem
    Nidem New Member
    Etterbeek
    Did You undertake any action to solve it? I noticed that it only happens when your car is parked for a while without being connected to a charging facility
  6. StefanSarzio
    StefanSarzio Member
    Herford, Germany
    Up to about two weeks ago it worked perfectly fine, no matter how long the car was parked. And most of the time I park without plugging in. And now it doesn't work when sleeping and plugged in. Plugged in or not doesn't make any difference to sleep mode.
    My SeC says they don't know of any problem and have no other reports than mine. They suggested to log out of the app and log in again. I haven't had the chance to do so, because this night my car didn't sleep because I forgot to revert the changed settings in teslafi.com. Right now it's charging. I will re-try when charging is over.
  7. Nidem
    Nidem New Member
    Etterbeek
    I turned the "always connected" on in the Energy Saving setting and now it works...
  8. Veritas1980
    Veritas1980 Electric Viking
    Malmö, Sweden
    For me, except for one time, waking up the car with always connected off, has never worked.
    I was sort of the impression that it wasn't supposed to work with the this setting, but I gather that car is meant to wake up after a while. This is also the reason I've never escalated the issue with Tesla.
    If anyone finds a good explanation for this, please let us know.
  9. StefanSarzio
    StefanSarzio Member
    Herford, Germany
    Your car simply stopped sleeping - which results in a higher vampire drain.
    @Veritas1980 Yes, if it sleeps then it should wake up within a minute of opening the app. I guess only Tesla can find an explanation - and solution! The more people report the problem the sooner they will get to it, I guess.
  10. Banker
    Banker Member
    Nijmegen
    same issue here in NL. does not wake up any more when the car is parked for more than 30 min. really annoying. didn't have this problem earlier
  11. Banker
    Banker Member
    Nijmegen
    signing off and in again does not solve the issue, neither does re-installing the app
  12. StefanSarzio
    StefanSarzio Member
    Herford, Germany
    I can confirm. Didn't help for me either. But it seems to be the first thing support wants you to do.
    Resulted in me wondering why my calendar doesn't sync any more - and having to find out again how to sync the calendar again and how to de-select the calendars I don't want synced. :-D
  13. Banker
    Banker Member
    Nijmegen
    called tesla, they advised a factory reset. Didn't work....
  14. Banker
    Banker Member
    Nijmegen
    They did not have any further tips to solve this. Bye bye app
  15. fredz
    fredz Member
    Luxembourg
    Same here, it always worked fine, but not anymore. But who says this has nothing to do with firmware? I'm on the latest 2017.28.4 cf44833. Before that it worked fine, but not sure if this is due to firmware. I can also not wake the car using TeslaFi's wake function. So it has nothing to do with the Tesla app, it's something deeper.
  16. SG57
    SG57 Vendor
    Spokane Valley, WA
    I had this issue a few months back, the vehicle would no longer wake up remotely through the APIs.
    I fixed this issue in minutes simply resetting both displays in the car - press and hold the scroll wheels for 15+ seconds, then press and hold the buttons above both scroll wheels for 15+ seconds.
  17. StefanSarzio
    StefanSarzio Member
    Herford, Germany
    Several people in the German TFF forum do, because they didn't get an update around the time the problem appeared.
  18. fredz
    fredz Member
    Luxembourg
    Tried this - it doesn't solve the problem...
  19. fredz
    fredz Member
    Luxembourg
    You have a link to that thread?
