Car says to connect to wifi to download even when wifi signal is shown and strong
Jake AZ
17
3
Prescott AZ
I got the notification that the new update was available and to connect to wifi. Although I've always been connected, and the display showed my network with a green check, the display showed a weak signal. I rearranged by router and sattelites and got a very strong signal shown by the display. I even deleted the network and reinstalled it. But I still get the "Connect to wifi" message. Any suggestions? I'd like to avoid to rebooting the computers (I've already done it several times for the display), if that would even work.
Jake AZ
17
3
Prescott AZ
Did you try to move the car? I beleive the Wifi antena is inside the driver side mirror.
The signal shown in the car is 3 out of 4 bars so it's stronger than it's even been when I received updates without a problem. (I moved a satellite closer to where the car is.) . Nevertheless, I moved the car out of the garage and the signal failed completely. The car has a green check inside a green circle so the "right hand" the car says it is actually connected. The "left hand" of the car still tells me to connect to wifi. Another case where the left hand doesn't know what the right hand is doing.
Reactions: N5329K
XHabjab
Helping to end the ICE Age
Feb 25, 2018
558
1,007
Georgetown TX
Make sure you don't have an extra level of login to make (eg. when connecting to a hotel or library router). Open the browser and see if you can load google.com or some other common website.
Jake AZ
17
3
Prescott AZ
The car is in my garage where it always was when downloading other updates. I'm going to try to log onto a website. I thought of this but forgot to do it. Thanks.
KenC
3,278
2,993
Maine
Try changing the channel on the network.
Msjulie
2,425
1,733
Monterey Bay Area
My router supports 5GHz and 2.4GHz and my car connected to both but could not download or do much with the 5GZ connection. Forgetting the networks and only reconnection to 2.4 fixed it..
Jake AZ
17
3
Prescott AZ
I finally got to chat with someone and it downloaded. I didn't change anything, including location of router. She didn't say why the update would not download earlier.
madcal
77
35
UK
I have exactly the same issue. Car is connected fine on WiFi (brand new Model S Peformance), can watch Netflix but refuses to believe it is connected when it comes to downloading an update.
Any more details on what fixed it?
Kevy Baby
Dis-Member
Aug 11, 2019
1,752
1,705
Brea, CA
Whether you are connected to WiFi has no bearing on whether your car is READY to receive the update: WiFi is only required for the actual download.
I don't regularly connect to WiFi. The I get the notification that an update is ready, THEN I connect to WiFI (hotspot on my phone during a drive) to download the update and then schedule the install (once DL is complete) that night.
khorton
27
51
Moses Lake, WA
I've got the same issue since yesterday. The Model 3 says "Update Available" and " Please connect to Wi-Fi to download ...". It is on WiFi, as evidenced by the IP address that comes up in the browser if I search " What's my IP address".
The car is in the same place as in my garage where it has gotten every previous update. I've restarted the car with two thumbs and brake. I've forgotten and reconnected to Wifi. I've rebooted the firewall and confirmed in the firewall logs that it isn't blocking the car.
What else can I try before contacting Tesla Support?
Reactions: Watts_Up
khorton
27
51
Moses Lake, WA
I cracked and did a chat with Tesla Support. They found that the link between my car and the download server was borked. They reset that link, and the download started immediately afterwards.
Reactions: Watts_Up
