For iPhone users, the Bluetooth key will not work if you force close the app.
Apps on the iPhone generally don’t run in the background, and you don’t have any way to tell if it is running or not. The Tesla app registers itself as a Bluetooth handler with the os, and then is notified when new Bluetooth connections are made. This way the app can be restarted when necessary but not always be running.Started to happen to me
Can you add more details? I have had this issue intermittently for the past couple of months. Right now the app is not running and it has (so far) worked fine. Are you saying that if I open the app, then force close it (so it is not running again) it will not work?
thx
This happens when the car goes to sleep, for some reason the button on the charger can’t be used to wake it up. It’s somewhat annoying but it isn’t a problem with your car, it happens to everyone.I never have issues unlocking the car, but I do have issues where it doesn’t recognize me when I try to remove the charger from the charge port. I have to open the rear door and then it lets me take out the charger.
When you force quit the Tesla app, it is unregistered as a Bluetooth handler and then stops working as a key.
If the os kills the application (ie, due to memory pressure) then it will relaunch the application. If the user kills the application then the app will not be started automatically - the user must relaunch the app before it will receive any new bluetooth notifications (Technical Q&A QA1962: Conditions Under Which Bluetooth State Restoration Will Relaunch An App). I was incorrect when I stated that it will be removed as a handler.Again, completely wrong.
It is registered for Bluetooth/background activity at INSTALL time. All apps get a time slice in background when iOS sees changes in Bluetooth devices (for app that are registered to allow it). If the app is not running iOS will start it in background and give it a chance to connect.
This is why you have to give ALL permissions. And location ALWAYS is part of it.
The app I developed has Voice status, so I know exactly what it’s doing in background.
You must have background app refresh, location always and Bluetooth all enabled.
If you have location set to always, and you cross a geographic boundary, then your app can be relaunched automatically. However, geofences have a radius of tens to hundreds of meters, so crossing a boundary is in no way guaranteed.
