Reddy Kilowatt
I'm very close to you, also, which makes it weird that you aren't having the same issues. Literally around the corner from Eastgate, off Planting Field.
So am I. I'm not having a problem with charging. But I cant use my voice commands that Tesla says will be fixed with Rev 10. Of course it is always the software. Gosh I hope they haven't screwed this up again. I just got 28.3.2 yesterday. I do swear we are charging slower. My sons 3 hasnt had any issues. He lives down near Ciro's.
Im off Sarazen on Glasgow, next street down, just off the golf course.
The highest I've seen on my Solar Edge inverter is 249, and lowest is 240, but I don't have a record of actual max and mins, of course. I've put in a call to the electrician that installed my HPWCs, but all he could really do is measure the voltage at the HPWC which we 99.99% know is going to be the same as at the inverter. It's at the end of a 100 Amp circuit that is about 50 feet away from the breaker panel on all new wire made for sustained 80 Amp loads. Obviously the voltage drop for no load is as close to zero as you can get and that's where we are when it's testing the voltage 'acceptability'. (I do know something about these things, as I was trained as an EE. )
I would say the voltage posted in your car is deadly accurate. A volt meter would be the same. Can you plug the 3 in first then plug in the X. did that make any difference. reason I ask would that pull down the static voltage level, hopefully enough to trick yours into charging. I will check the voltage on mine tonight.
If you were to ask the power company to come out the best they could do is lower the voltage taps in the transformer 2 1/2 percent. But i doubt they have taps. they get the cheapest they can. I think we have 5 houses on one transformer.
Do you have a whole house surge arrester / TVSS on your house? I do. Tesla has the white Auto transformers on most of the Super chargers to clean up the power. Leesburg has them. I forgot what Gainsville has.
I would be curious what you read when the temperature drops tomorrow.
