gateway reboot dos not help (I tried), you really need to reboot cebtral body module and there's no user-visible way to do it short of power cycleOne trick I use to force a full boot is to change your wheel size to something else and then back.
The power down does not seem to power down, but it makes lots of clunks like it's doing a full reboot when you change wheel size.
Takes a while too.
that's the thing that reboots after you change gateway config that stores wheel type and other stuff.Gateway?
Yesterday I changed my wheel size (because I changed my wheels). It resulted in a full reboot.gateway reboot dos not help (I tried), you really need to reboot cebtral body module and there's no user-visible way to do it short of power cycle
This was in my 2019 Model X LR with 2020.32.2.
that's if you have dead battery, this is different because the doors still open fine from teh fob andsuch. The problem is the module inside the car that determines if the fob is inside is in a bad state and needs a reset. there's an internal aleart about it that regular people cannot see but since I had this same issue on my car - I know what the problem really is.What happens if you hold the key in the special place in the center console, and press the brake?
The manual has a picture of the location.
Both screens went black, power to the vehicle turned off completely, everything remained completely black for what seemed like 2 minutes or longer, then gradually the screens and vehicle came back to life. It was much different than simply rebooting the two screens while the vehicle remained on.I don't know what you mean by a "full reboot". I rebooted gateway (same thing as if you change the wheel type) when I met the problem and it did not help with the vccsec in bad state. I had to send a manual "reset bccen" command.
sounds like a normal gw reboot to me that you can achieve with a brake pedal pressed and the two scroll-wheels on mcu2 car.Both screens went black, power to the vehicle turned off completely, everything remained completely black for what seemed like 2 minutes or longer, then gradually the screens and vehicle came back to life. It was much different than simply rebooting the two screens while the vehicle remained on.
