Car won't go into Drive or Reverse?
Discussion in 'Model 3' started by Fudd, Nov 6, 2018.
  1. Fudd
    Fudd Member
    DC
    I'm on software 2018.42.3. This morning I got into the car (using my phone), Tried to put it in reverse and nothing happened. Tried again and again, pressing hard on the brake, still nothing happened. Drive to put in Drive (just to see if it would), no luck. After about 30 seconds of trying it went into reverse.
    I've experienced this problem before, before the version 9 update, and I thought it was a fluke or "just me"... but now it has happened again. Has this happened to anyone else?
    Oh, and on top of all that I realized soon afterward (while driving) that I had no cruise or AP. Others have experienced this issue, too: 2018.42.4 NO AP?
  2. GregRF
    GregRF Squirrel Power
  3. myster2
    myster2 Member
    Austin TX
    Last time this happend to me, I got out and open/closed all the doors, got back in and everthing was working.
  4. tomas
    tomas Out of warranty...
    Chicago/Montecito
    Yes this is solution. Restart the car. PITA but it works.
  5. Fudd
    Fudd Member
    DC
    Thanks. Don't know how i didn't find that post!
  6. Fudd
    Fudd Member
    DC
    OK, but seriously this shouldn't be happening. I love everything Tesla, but even a fanboy's patience can be tested if poked long enough with these ridiculous annoyances.
  7. scottm
    scottm Legacy account
    Canada
    No other error messages or pop-ups to clue you in? (door ajar?)
    Maybe driver seat detector is not detecting your butt presence? Are you a lightweight person? Are you using a pillow, seat cover, or booster?
  8. tomas
    Chicago/Montecito
    When we had issue like this with my wife’s 3, the PRND would not even appear without a restart. They said it was software issue that was not unique and would be fixed in future software release. Has not recurred since recent updates.
  9. Fudd
    Fudd Member
    DC
    I'm close to 260lbs... I do have a seat pad (not cover), but I doubt it's going to interfere with it detecting me. If it happens again, I'll try removing it and post the results...
  10. Rsdavis9
    Rsdavis9 Member
    Nh
    Happened twice to me with 42.2.
    Trying F then R and eventually it works.
  11. scottm
    Canada
    Do you mean D and then R on the stalk?
    Although, I like the use of F for Forward instead of D for Drive... as you can see here
  12. ATechGuy
    ATechGuy Member
    Portland, ME
    It's happening to me as well. I thought it was because I had changed something on my phone, but now that I think of it, it started happening around the time when I took on the 42.2 update.
  13. AcuraDude
    AcuraDude Member
    Midwest
    This started happening to me more often so I set up an appt with my SC. Within a 1/2hr of setting my appt online, they called and said they diagnosed my car and didn't see anything physically wrong with the stalk. He then told me it's most likely a bluetooth issue (Pixel 1). I told him I didn't have any problems with the car auto unlocking, but he said just because the bluetooth unlocked the car doesn't necessarily mean it'll also start the car. Even though I told him I never got the 'Place card on center console' message, he said to try that the next time it doesn't engage in D or R. I doubt it will work, but I'll give it a shot the next time it happens. Outside of that, he said even if I brought it in, there wasn't much else they could check.
  14. CCIE
    CCIE Member
    CT
    I’ve had this happen a few times. I noticed the last time that the screen was also completely unresponsive. Waited about 30 seconds and everything just started working on its own. Seems like the car just takes a little bit to completely wake up sometimes.
  15. captreynolds
    captreynolds Member
    San Francisco Bay Area
    I've had this issue a few times. In my case, it was a problem with the phone key. Simply unlocking my phone (iPhone X) made it recognize the key and let me switch into gear.
    There appears to be a bug where the "place keycard here" animation does not always pop up even though no key has been detected. So there is no indication that the key is the problem. I confirmed this by bringing up the keys preference pane, and as expected none of the registered keys showed up as "present."
  16. scottm
    Canada
    Guys who have this issue... and is repeatable.... ditch the phone keys for a bit. (De-register it)
    Use your card key only for a few days. See if she no-go into D or R even when the card key is placed correctly. Even if the animation comes up or doesn't... just put it where it needs to be and select the gear.
    No gear takes? It's a bug, let us know and Call Tesla.
