Car won't unlock by walking up to it
Discussion in 'Model 3' started by YusufT, Jul 7, 2018.
  1. YusufT
    YusufT Member
    Vaughan, Ontario
    Before the most recent update, I had an 100% success rate of unlocking the doors using my phone as a key. After this update however, it feels like 70% of the time it fails to unlock, and I turn my bluetooth off and on again and same thing, won't unlock even when under bluetooth it says it's connected to the Tesla Model 3. I know it's connected because my music started playing. But the damn doors won't unlock. After looking stupid for a couple minutes I unlocked the car through the app, and it didn't require me to use a keycard to start, everything else worked. Am I the only one here?
    Phone: iPhone X
  2. dek526
    dek526 Member
    Los Angeles
    i started having issues unlocking the doors 2 updates ago. you def aren’t the only one...hoping they address this issue soon as i often have to whip out the valet card to unlock the door
  3. Need
    Need Active Member
    SoCal
    Just to be clear, you did push and pull the handle right?
  4. ewoodrick
    ewoodrick Active Member
    Buford, GA
    First, there are two pairings with the phone and the car, the audio and the security. They aren't related and you can have one without the other.
    It sounds as may have lost the security pairing, easiest option, make sure you have your card key, remove the car from the app, remove from car, add from car. Do this from the keys section, not the music.
  5. YusufT
    YusufT Member
    Vaughan, Ontario
    Oh you were supposed to push and pull the handle? Makes so much more sense now! /s
    Okay good to know they’re two different pairings. Have I really lost the security pairing if it works 30% of the time? Wouldn’t it not work at all? Alright i’ll give it a try. This morning I did a reset (brake pedal + two buttons for 10 sec) and the car is working as intended so far.
