Car won't wake-up after 4+ hours of sleep-mode
Discussion in 'Model 3: Battery & Charging' started by GreenFreaK, Sep 19, 2018.
  1. GreenFreaK
    GreenFreaK Member
    Pittsburgh, PA
    Model 3 LR AWD (8/18 manufactured date - VIN 68xxx) - SW 2018.32.6 08c12e6
    When my car goes to sleep (at work or at home), it doesn't seem to want to wake up anytime it sleeps for longer than 4 hours. I've tried via the iPhone widget, the iPhone app, and using TeslaFI's "wake" control. Nothing wakes it up.
    I have to be within Bluetooth range so my phone key is connected, then unlock / lock the vehicle first; only then does it finally wake up. I also noticed that if I don't pre-wake the car and get in, there's no Internet connectivity and the LTE has a slash though the antennas (for about 5-10 seconds, then it comes back).
    Has anyone else experienced this issue? I have "always connected" toggled on along with "allow mobile access".
    Thanks!
  2. Larry Hutchinson
    Beaverton, OR
    Just got my 3 on Wednesday.
    Yes, I see this also. Even my S is often impossible to wake via the phone.
    Where do you find "always connected" and "allow mobile access"? I know where "always connected" is on my S but can't find it on the 3.
    I will probably report this elsewhere, but I have found that if overheat protection is turned off, the car goes into a very deep sleep mode in about 15 minutes. Waking the car with the door handle results in a black screen for 25 seconds followed by the T and then the normal screen. It looks like a complete reboot rather than waking from sleep.
  3. quantumslip
    quantumslip Member
    Houston, TX
    Just wondering, are y'all hooked up to wifi when this issue happens? Or just LTE?
    For me, this happened to me at my parent's house, and after digging around I found that when I park there the LTE signal is weak (like 1 bar, maybe 2). It almost feels like when the computer goes to sleep this signal gets even weaker to the point where it just dies. If I wake up the car via alternate means (unlock / lock) then it works. Once I hooked up my car to their wifi then the issues went away.
  4. Larry Hutchinson
    Beaverton, OR
    I'm not on WiFi on my 3 as it can not see my base station. My S, in the same spot in the garage has no trouble.
  5. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
    I’m having the same problem and with it getting cold out it’s really annoying to not be able to preheat my car. I tried the overheat protection trick and it still won’t wake up after a long sleep. In my case it doesn’t matter how many bars I have. I’ll sit for 30+ minutes trying to wake it up over and over again.
  6. minsup23
    minsup23 Member
    Chicago, IL
    I guess no one has a solution for this?
  7. IdaX
    IdaX Member
    Moscow, Idaho
    Sounds less like "sleep" and more like "medically induced coma".
    • Funny x 2
  8. justaute
    justaute Member
    Fruit Heights, UT
    Hmmm...this could be troubling to me as I usually park at the airport for days at a time.
  9. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    The wakeup from the app, I believe, only occurs over cellular. Since when the car goes to sleep, it drops the Wi-Fi. So the car needs cellular to wake up.
    The phone key only works over Bluetooth.
  10. roguenode
    roguenode Member
    Nederland (CO)
    This is what I've found. My car is WiFi only at my house since there's no cell service at the location. I really wish Tesla would allow the option to stay on WiFi. It's really throwing a wrench into my Teslafi scheduled events when the car is at my home.
  11. Mary Starfnbu
    Mary Starfnbu Member
    Bay Area
    I'm finding this discussion very interesting. I was looking for just this subject and found this thread. My car (2018 S 100D) seem to take longer and longer to wake up in the morning. It won't respond to my fob and if it is plugged in, it won't let me remove the plug. Today I had success by opening the Tesla app on the phone and it began waking up. --dash first and faded "T" on the screen. The whole process took at least 3-4 minutes. I seems to take longer everyday. New battery in the fob didn't help. Cellular and wifi are close by, so signal is available. Ideas?
  12. jjrandorin
    jjrandorin Another BMW convert
    Riverside Co. CA
    This issue was "fixed" for most of us who had it with firmware update *.50.* . I doubt that anything that people were talking about here is relevant for your model S.
    Since its a model year 2018, you should make a note of the last time it happened and take it in for service.
