Carbon Fiber Rims
Discussion in 'Model S: Driving Dynamics' started by AngelArm1110, May 24, 2015.
  1. AngelArm1110
    AngelArm1110 Member
    Orillia Ontario
    I've been living under a rock, because I just found out that Carbon Fiber Rims exist, and the first thought I had was how would these affect the performance of a Model S. I'm torn right down the middle between an 85D and a 70D, but taking either as a starting point, I was wondering if the more mechanically inclined on this forum could speculate on the possible benefits and detriments of such a modification
  2. Tdriver
    Tdriver Member
    Palm Desert, CA
    The lighter weight will reduce unsprung weight and that will improve your ride on less than perfect pavement......but they will be very very expensive. Many shops will probably not want to change tires with them.
  3. mhpr262
    mhpr262 Member
    Old Europe
    The wheels are the best place to start saving weight. There are multiple benefits - not only do you reduce unsprung weight and thus improve comfort and shock absorber performance, you also reduce overall weight of the car for better linear acceleration AND you reduce the spinning mass which ALSO improves acceleration.
    I shudder at the cost of running into a pothole or into the curb, though ...
  4. AngelArm1110
    AngelArm1110 Member
    Orillia Ontario
    yea.. that kinda gave me a chill just now haha, but yea maybe if I ever wanted to drag race it I'd get them then
  5. AMPd
    AMPd Active Member
    Northern California
    For the price of the carbon fiber wheels you can just upgrade to the p85d and get better performance.
  6. Kristoffer Helle
    Norge
    Why worry about potholes. A lighter wheel won't take damage. The problem with regular wheels is that they are to heavy to lift fast enough.
  7. SwedishAdvocate
    SwedishAdvocate Active Member
    Sweden, Earth
  8. RobStark
    RobStark Well-Known Member
    City of Champions, USA
    Vitesse-AuDessus hand laid custom carbon fiber wheel set $40k
    Carbon Revolution set of 19's at $16k
    ESE Carbon Company set of 19's at $8k
  9. JST
    JST Active Member
    I'm pretty sure the bolt pattern is going to make those incompatible, but the fact that Ford is spec'ing them for a relatively mainstream product will no doubt drive prices on these components down. Should also answer questions about durability.
  10. JER
    JER Member
    Bristol, UK
    I heard of a European company making hybrid CF/Al rims with most of the mass advantage of CF and lower cost. Don't remember any details though.
    Unsprung mass is indeed the best mass to shed on a car, but don't expect miracles from just shaving bit off the rims. CF is good, but it's not magic pixie dust.
    I'd submit that if you're considering these but didn't delete the pano roof from your Model S order, you're officially insane. ;)
  11. ERP
    ERP Ludicrous Member
    Colorado Springs
    I have a hard time seeing any Tesla owners splurging on carbon fiber rims. It sounds fantastic but is so cost prohibited, and the durability is unknown.
    But you don't need to go carbon fiber or even forged aluminum to see significant weight savings. I have 21" non-staggered turbine wheels so I'm starting with a heavy setup. I need to put together a 19" winter set and here's what I've found.
    21" Turbine Wheel: 35 lbs
    Continental Tires: 27 lbs
    Rotors: 29.5 lbs front, 28 lbs rear
    Total Weight: 363 lbs, all four wheels, tires and rotors
    19" OZ Wheels: 23 lbs - Not the absolute lightest wheels, but not unreasonably priced for the weight.
    Michelin X-Ice tires: 28 lbs - Heavier than the continentals due to larger sidewall.
    RB Two Piece Rotors: 21 lbs front, 16.4 lbs rear
    Total Weight: 278.8 lbs
    That is a savings of 84 lbs. A significant amount of rotating mass. I'd like to find an online calculator which shows the energy it takes to spin 84 lbs from 0 to 75 mph. The location of the mass moment of inertia is unknown so it would have to be estimated. I know a majority of that energy can be reclaimed through regenerative braking, but 20% or more is going to be wasted even in ideal conditions.
  12. RobStark
    ESE E1 19x8.5 wheel weight is 11.5 lbs.
    Buying light weight non-forged aluminum rims is asking for bent rims, particularly on a heavy Model S car. You can take the view they are cheap and you can buy several and it still cheaper than Carbon Fiber but there is also the hassle and performance difference.
    No, we don't know long term reliability for fact. We also don't know the long term reliability of Model S battery pack and that does not stop some of us from spending $130k-$150k on a P85D or a P90DL.
    We are talking early adopters that spend $$$ on new unproven tech. In that light $8k does not seem like a stretch for a set of wheels if you are the kind of person that previously purchased HRE or RUF wheels for you Porsche or Brabus wheels for your Merc.
    The main reason I don't see a lot of P90DL owners buying carbon fiber wheels is because they don't know about them or think they all are hand laid $40k sets.
  13. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    I am about to order a set of ESE Carbon fiber rims - 19 inch x 8.5 inch. Will let you know how it turns out. BTW Carbon Revolution rims are now standard equipment on the Mustang SVT. The ESE Carbon rims are $2K each - If I could get them to call me back I would have already ordered them..
  14. Zybane
    Zybane Member
    Washington D.C.
    I was thinking about the ESE Carbon rims, but the style doesn't do it for me for $8K. More function over form purchase IMO.
  15. artsci
    artsci Sponsor
    Timonium, Maryland
    These wheels won't bend when you hit a big pothole. But will they just shatter? The consequences will be far worse than a mere bent wheel.
  16. Zybane
    Zybane Member
    Washington D.C.
    Carbon fiber will eventually shatter, but remember that occurs far after an aluminum wheel has been destroyed.
    The modulus of carbon fiber is typically 20 msi (138 Gpa) and its ultimate tensile strength is typically 500 ksi (3.5 Gpa). High stiffness and strength carbon fiber materials are also available through specialized heat treatment processes with much higher values. Compare this with 2024-T3 Aluminum, which has a modulus of only 10 msi and ultimate tensile strength of 65 ksi, and 4130 Steel, which has a modulus of 30 msi and ultimate tensile strength of 125 ksi.
    • Informative x 3
  17. artsci
    artsci Sponsor
    Timonium, Maryland
    So the longevity of a carbon fiber wheel should not be a concern and given the data you cited the odds of pothole damage are far, far lower?
  18. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    I went with TSW Nurburgrings which were about 20 lbs each and half the price of Tesla's 21" option even with the spare rim I bought (and I even got to use Pilot Super Sport rubber which I prefer). The extra 9 lb x 4 rims in rotational inertia and unsprung weight reduction is not worth the extra cost and exposure with carbon rims unless you (1) have too much money or (2) just love the idea of CF rims.
  19. Zybane
    Zybane Member
    Washington D.C.
    Correct.
    Which size TSW's did you go with? 20 lbs sounds a bit low. According to TSW you don't drop down to 20 lbs until you get as small as 18" wheels:
    Nurburgring Alloy Wheels by TSW
  20. Xenoilphobe
