Carbon fiber side view mirror caps and wha't under them
artsci
Sponsor
May 10, 2012
6,252
3,221
Timonium, Maryland
At the Great Appliqué Installation Event at delanman's house a few weeks ago with the help of SUPRKAR we also installed carbon fiber side view mirror caps on my car (SUPRKAR already had them on his).
We started by removing the painted caps and here's what we found underneath -- the GPS and wifi antennae.
As the carbon fiber partially blocks the signals SUPRKAR installed a signal booster. With that the GPS, wifi, and phone connections are better than stock.
Here's SUPRKAR placing the carbon fiber cap on the mirror. Easy to do -- just snaps on.
The final result is much better than the vinyl carbon fiber warp solution.
JPP
3,047
1,279
SF Bay Area, CA
...any idea where AM/FM antennae are and if a signal booster can be used for them? My 2013 build has horrible terrestrial radio reception, and my wife's new June 2015 build has way much better reception. I also would not mind a booster for my cell data antenna (...old 3G...my wife's new 70D has LTE).
artsci
Sponsor
May 10, 2012
6,252
3,221
Timonium, Maryland
I'm thinking of this.
Would you mind sharing the signal booster models that were used
It was a Wilson Electronics Moble 4g Cellular Signal Booster Kit.
- - - Updated - - -
Don't know if it boosts radio signals but you might want to check this out.
artsci
Sponsor
May 10, 2012
6,252
3,221
Timonium, Maryland
Would I be able to get more info on these CF caps please? E.g. where to get them and how much they cost.
Carbon Fiber Element in New Jersey. Sent them a set of stock caps and they covered them in CF I think they were $500.
- - - Updated - - -
Me too! Also, where did you mount the Wilson antenna. In the cap? Will it work with 3G or do I need to upgrade?
Thanks!
The antenna was mounted under the nose cone.
