Carbotech AX6 brake pads for Roadster wanted
Discussion in 'Want to Buy' started by lmore, Mar 27, 2014.
  1. lmore
    lmore Member
    Trondheim, Norway
    I need these shipped to AZ at the latest Wednesday. They don't have them in stock, that's why I ask here.
    Both rear and front are of interest, but front is most important. Thank you!
  2. wiztecy
    wiztecy Active Member
    Best bet would be to personally call any trusted website that advertises them and see if they have any in stock. Most likely the push the order to CarboTech directly, and if CT is out then they're out too. Also follow up with CT every couple of days to see if they have any new shipments of inventory. Otherwise you just have to luck out if a member has them, is able to delay putting them on, or wants to put the Bobcat 1521's on after they purchased the AX6's.
    Good Luck.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Just call Carbotech.
  4. wiztecy
    I took that as he did,but I could be wrong.
  5. lmore
    lmore Member
    Trondheim, Norway
    Thanks for the help! I emailed CarboTech. It was forwarded to KNS Brakes INC, "Carbotech forwards retail inquiries to us.".
    I also contacted several resellers I found on the web, but no one had them in stock.
    Perhaps I should try to call CarboTech today...
  6. strider
    strider Active Member
    NE Oklahoma
    Yeah, call carbotech directly and see if they have them. Otherwise I'm using the 1521's and am quite happy with them.
