One of the appeals of the MY is the ability to comfortably sleep in the cargo area. There are plenty of videos about this and there are products for it like the Tesmat. While I was perusing the owner's manual I saw these limits:
CAUTION: To avoid damage, never load more than 130 lbs (60 kg) on the rear load floor (above the lower trunk compartment), 285 lbs (130 kg) in the large lower trunk compartment, or more than 50 lbs (23 kg) in the shallow lower trunk compartment. Doing so can cause damage.
The weight limit above the shallow lower trunk compartment is not given. One possible interpretation is the total weight limit for part you would sleep on is (130 + 50 =) 180 lbs which is less than what many people weigh. Two people would very likely be over the the limit. Should I ignore the warnings or should I give up on sleeping in the cargo area? Any thoughts?
