So, I just got it running! Thanks Michal!!!
after the failed install last night, I got up to see you all working hard to give feedback and Michal putting out 44.2, it was very encouraging.
i downloaded 44.2 single file, took my 2012 mbp a while to write to the 64gb sd card. Then, it took quite a while to boot up in the car for the first time. And like Michal mentioned on the installation notes, if cannot connect to the WiFi, give it some more time. My first try, was like last night, cannot connect……, then I clear browser history again and also rebooted car, second try right after, still no go. I waited, Michal said give it 5-10 minutes, then, I tried again and it connected. I offlined My phone ahead of time so it does not auto connect to car play, went into autokit settings to make sure things are set right. Afterwards, I turned phone bt and WiFi on and it connected. It’s now working and it is faster than 38.1, which was quite choppy in my case. i use Amazon music occasionally and it was too much for it on 38.1, now it seems quite smooth.
another note to fellas above, I have same lte stick and Tello sim, it is working in my case. Full blue light from very early on during the boot, also autokit was up and running quite early.
car updated this morning to 36.6, not sure if this made a difference but worth mentioning. Also my car is 21 Y with intel chip.
hope everyone got theirs running!
cheers,
also, powered by cigarette usb plug, usbA to usbc to rpi on off switch, to rpi4 4gb.
