The car's dashboard does NOT show the TOTAL consumption of the energy that entered the battery!
This is a bold statement, but also a very verifiable one.
For 1 month, after each daily drive,
For every single daily drive, I needed to add more kWh to the battery (refilling it to 70%), than what the car said were the kWh consumed in the previous day.
To be perfectly clear: I’m not talking charging efficiency. Only the “in” and “out” of the battery. You can read more about that in this other thread.
The plotted data shows a very interesting pattern:
I don’t know the definitive explanation for this, but:
I’m creating this topic:
That being said, I love my Model S. I really think it’s the best car in the world and wouldn’t change it for anything (besides a P100D!)
- I took note of the kWh used, reported in the car's dashboard (Model S 85D)
- I charged every night to exactly 70%, to top of that day's consumption,
- After the charge, I took note of the kWh added to the battery (you can get that number from the car’s dashboard after charge completion, or from the car’s API).
- If you drive gently (~160 Wh/km), for each 50 kWh the car says you used, you can actually re-add around 52 kWh to the battery (~96% usage accuracy).
- If you drive like a maniac (~280 Wh/km), for each 50 kWh the car says you used, you can actually re-add around 59 kWh to the battery (~84% usage accuracy).
- It’s crystal clear that you can add more energy to the battery of the Model S, than the energy the Model S says is leaving the battery… and that can’t be right!
- Because the energy entering the battery is coherent with the expected charging efficiency (see this thread), I can only conclude that the Model S is not reporting the TOTAL energy leaving the battery
- Looking at the pattern of the graph above, my speculation / suspicion, is that the Model S is NOT measuring the battery’s discharge (in)efficiency:
- If you discharge a lithium (or any other) battery at a high C-rate, you won’t be able to achieve its rated energy capacity. For example, you’ll have energy being wasted to heat;
- To hear if you can replicate the experience (charge to X%, drive, take note of the kWh used during that drive, charge to the same X%, take not of the kWh added to the battery and see if it matches)
- Hear your other possible explanations for this.
