Cat urine on passenger seat...
T35LA_AC
Calgary, Alberta
Took cat to the vet in a carrier resting on passenger seat in M3. Peed all over passenger seat... I had car cleaning wipes and paper towel and used immediately. No stains on car seat. But it’s been a few days and the odour is still there. If you’ve ever smelled cat urine, you know how awful this is. Thoughts on removing odour from car/seat? Not sure what’s safe to use on these seats. Thanks!
aiya
16
9
NYC
You're going to need to use an enzymatic cleaner to neutralize the odor. It is likely in the foam and you may need to replace the seat bottom if the smell doesn't come out.
Kevy Baby
Dis-Member
Aug 11, 2019
1,782
1,741
Brea, CA
As a long time cat owner, I will tell you (if you don't already know), that you're in a tough spot - cat pee is a tough one.
I second using an enzymatic agent. Test for staining (especially if you have white seats) and then use copious amounts - saturate the area (though I am not sure about electronics such as the seat heater). Hopefully that takes care of it; might take a couple of rounds.
Good luck: I feel bad for you!
David99
4,850
7,021
Brea, Orange County
Get yourself a Bissel machine. They are relatively inexpensive but work wonders. The key thing is you can only get the smell out if you get the urine out. Wipes, sprays, odor killers just *try* to neutralize it. The Bissel (or similar machine) soaks the area with water and detergent which dissolves the dirt/urine and then sucks it out of the seat again. This way you really get it out.
I have used it on cat urine, vomit, spilled milk shakes and other nastiy stuff. I usually do two or three passes and then finally do another pass just with clean water to also get the detergent out. In fact I do that about twice a year to all my seats.
axhoaxho
167
206
San Francisco Bay Area
Try Nature's Miracle. I have been using it for years, it worked pretty well.
https://www.amazon.com/Natures-Mira...3&sprefix=nature's+miracle+cat,aps,204&sr=8-4
Mishakim
146
122
Boston, MA
Does that penetrate the vegan leather to get into the foam and back out?
Chickenlittle
Banned
Sep 10, 2013
2,781
4,943
Virginia
Can’t help with idea for what happened but in future put towel in carrier for cats comfort and to help if problem happens again
David99
4,850
7,021
Brea, Orange County
It penetrates as much and as deep as any liquid does. It sucks out most of it, not all of it of course. Just saying, out of all methods, this is the most effective based on my experience. Everything else just pores more into the material and stays there.
bpobill
289
166
There are so many seat and seat pieces on ebay. I would replace the damn thing. Cat pee is not coming out unless you take the seat apart and clean it from the inside.
SMAlset
8,754
9,363
SF Bay Area
I can’t imagine what it will smell like with the seat heater on. I’ve had cats too and too bad you didn’t have the cat carrier on a all-weather cargo mat in the back. At least you’d have a chance getting the odor out. I think there’s a good chance of replacing the seat. Don’t wait until Summer time.
T35LA_AC
Calgary, Alberta
Thanks. Any special detergent I should get in addition to the Bissell Machine?
T35LA_AC
Calgary, Alberta
I wanted to buckle her carrier in with the seatbelt ... never again haha. Any idea what it costs to replace the seat bottom?
