stopcrazypp
All current carrying devices can handle higher currents for short amounts of times (that's where the 80% derating comes from for continuous loads for example for EV charging). The question is how many minutes the adapters can handle at the given current, and how much does the temperature rise? The same question applies to the third party options.Additionally, if the label on the Korean adapter was indeed factually correct, then how did anyone get above 120 kW with the adapter then? It says "300 amps" on the sticker and you can't pull more than 400 volts on a M3/MY (slightly more with MS). 400 volts x 300 amps = 120 kW at best. There are numerous YouTube videos of people pulling 200 kW. My Korean adapter wasn't even warm when I was pulling over 120 kW.
It perhaps doesn't quite matter yet due to taper in existing Teslas, but with cars with bigger packs like the Cybertruck, it will begin to matter. This adapter is just fresh released but it'll be used for years, when things will change.
