Eno Deb
Well, this thread is about CCS.The 2017 comment is referring to the Chademo adapter, which has existed and worked with S and X for many years.
A good gesture for current adapter owners is a good way to look at it. I’d say people shouldn’t buy it assuming the CCS version will be out soon. The CHAdeMO adapter is more awkward to store and use, more expensive, slower charging and tied to a limited network. Electrify America is putting the final nails in the coffin for CHAdeMO.I doubt many people will buy this thing going forward.
I am kind of surprised, Montreal area seems pretty good to me for SC coverage. North east bound to Rivière du Loup you have 3 I believe. You can make Toronto no problem...unless you have the Canadian SR. Then, I understand your concern.I’ve been looking at a couple roadtrip paths here from Montreal QC and its really not easy with a Standard range to go far. I cant wait for Tesla to release this adapter. In fact, it’s currently a reason to not buy a Tesla unless you have another vehicle for roadtrips in my area.
I have the Standard Range Plus. Not the canadian sr of course. Try to plan a trip to Prac National de la Gaspesie. You’ll see that it’s not really doable without using slow chargers since we’re currently incompatible with the Flo/CircuitElectrique fast charger network that uses Chademo and CCS.I am kind of surprised, Montreal area seems pretty good to me for SC coverage. North east bound to Rivière du Loup you have 3 I believe. You can make Toronto no problem...unless you have the Canadian SR. Then, I understand your concern.
Ok, i realise that, however as far as Canada is concerned, Quebec is not the worse...I have the Standard Range Plus. Not the canadian sr of course. Try to plan a trip to Prac National de la Gaspesie. You’ll see that it’s not really doable without using slow chargers since we’re currently incompatible with the Flo/CircuitElectrique fast charger network that uses Chademo and CCS.
But also note that Tesla had to make a hardware change to the chargeport to make the adapter possible - which they've now done.
We don't know for certain yet if a passive adapter is possible with the North American version of the Model 3 without modifications. We do know that Model S/X produced prior to May 2019 need a hardware modification.Hardware change on the 3’s chargeport to make an adapter possible?? Or you meant on other models?
That applies to the European Model S&X, we have no idea if the NA Model S&X will be compatible with a CCS adapter or what changes will be necessary.
Hello,
ccs combo 1 adaptor to ccs combo 2 exist it is passive adaptor so if the north america model 3 use css protocol in back end it mater of do passive adapter
I contact the compagny produce ccs combo 1 adaptor to ccs combo 2 they say they could develop the adapter is they have order of 100 of those futur adapter
on the website you find the contact info
CCS1 to CCS2 Adapter - EV Plug - ShenZhen SETEC Power Co., Ltd.
seb
Vu le nombre de Tesla au Québec, il doit y en avoir pas mal !Oh come on, fancy trip to parc de la Gaspésie...
Try réserve faunique LaVérendrie and beer is on me if you get past Rouyn-Noranda
(Coudonc on est combien de Québecois à se répondre en anglais???)
Try réserve faunique LaVérendrie and beer is on me if you get past Rouyn-Noranda![]()
well, if you sleep there (maniwaki) or in Val d'Or you can make it.Actually you can do it without much problem in summer (M3 LR RWD):
Ok not CCS, but it will do plenty for me.
CHAdeMO Adapter
Not enough for a Lagavulin 16 but plenty to open a good beer, cheers!
Could be an good idea, either for a group buy thing or a little sideline.I'm really on the fence about buying the CHAdeMO adapter. It was noted earlier in the thread that there is no technical barrier to implementing a small passive adapter for CCS on the Model 3... I like the idea of smaller and cheaper ($271 AU), with higher power capability to boot!
