Cell format discussion - Cylindical or Prismatic or Pouch?
Discussion in 'Battery Discussion' started by thegruf, Jun 26, 2018.
  1. thegruf
    thegruf Active Member
    UK
    A sTesla seems to be increasingly distinct in using cylindircal cells, are others making a mistake by mostly using Prismatic cells eg Jaguar iPace?
    Or is Telsa committed to cylindical cells for historical reasons and reluctant to change solely due to tooling setup costs?
    what are the advantages/disavantages of each cell type in terms of
    power to weight
    thermal management in pack design
    longeivity aka degradation
    fire risk or control
    recycling
    manufacturing cost/KWH
    and does one type emerge overall leader?
    asking as others here are far more aware of the technicalities; but for sure Tesla seems to be carving a different path from most with this.
  2. mongo
    mongo Well-Known Member
    Michigan
    Cylindrical have better heat dissipation (volume to surface area) than large (thick) format cells. They also do not require external compression. Multiple smaller cells increase fault tolerance and safety, each cell is individually contained and fused.
  3. Brando
    Brando Active Member
    Bainbridge Island, WA
    You should start by reading/reviewing this "Battery Discussion" section.
