Cell Types in the model S
Discussion in 'Model S: Battery & Charging' started by Mitrovic, Nov 28, 2012.
  1. Mitrovic
    Mitrovic Member
    Bern, Switzerland
    I assume it is still the Panasonic cells in the model S?
    Does anyone know what exact type off cell is used?
    Thank you
  2. JRP3
    JRP3 Hyperactive Member
    Central New York
    I believe there are different types, depending on the model. I think the 85kWh pack uses what Panasonic is calling their NNP cell, which I think is a Lithium Nickel Cobalt Aluminum Oxide variant. I think the smaller pack sizes use a slightly different more conventional LiCo cell with lower specific energy density, so pack size and weight stays the same at lower pack capacity.
  3. qwk
    qwk P130DL
    This is mostly speculation, so take it with a grain of salt, but supposedly the Rav4 and 40 kwh Model S use the 2.2mah cells also used in the roadster(that's why no supercharger use is allowed). The 60kwh and 85 kwh supposedly use the 3.1ah ncr18650a cells. Both the 40 and 60kwh use the same layout/cell count only different cells.
    EPA cycle range charge is 140, 200, 265.
  4. Beckler
    Beckler Member
    Canada
    Panasonic now has 3.4 Ah 18650's. I know, I just bought two. BTW, with the news about battery replacement options, they should have a DIY option where you can solder together your own. :D Also they should have disposable alkaline packs. Duracell would like that.
  5. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    This sounds about right, and a most reasonable explanation for the no-SC-for-40s policy.
