Center Cap Removal Tool
siai47
163
189
Deland, Fl.
If you have a Garmin or similar windshield mount GPS, the suction cup on the mounting bracket will pull the center caps off both the model 3 and model S. The 3's caps have a slight crown and you have the set the suction cup tight and then pull the lever on the mount (as you would when putting it on a windshield). Pull the bracket and off the caps come.
swaltner
1,586
1,566
Kansas, USA
The tool included with the kit is to remove the lg nut covers, although your fingers work a lot better than the included tool for that job.
