Center console cover stuck
Discussion in 'Model X: Interior & Exterior' started by lloyds, May 20, 2016.
  1. lloyds
    lloyds Active Member
    Bay Area
    Anyone else have this issue? It won't open or close.
  2. swesson
    swesson Member
    Denver, Colorado
    I did have this issue. It wasn't completely stuck, but when I got my hand underneath it, I found a thin piece of plastic (almost paper-thin) that was creating an obstruction. I pulled it out and it hasn't stuck since.
  3. vandacca
    vandacca ReActive Member
    Hamilton
    Someone also reported that there are a couple of cables running behind the console (e.g. OBDI) and if they aren't tucked away properly, they can obstruct the console from opening.
  4. lloyds
    Bay Area
    You are right...I put my hand to the very end and feel wires there...tried pushing it out of the way, but it is very tight. Guess another trip to the SC again..
  5. RossRAllen
    RossRAllen Member
    St. Helena, CA
    This happened to me after a service center visit. The panel wouldn't open all the way because it was jammed by a cable connector about the size of a wine cork that had fallen into the mechanism after the service visit. I reached in, felt the obstruction, pushed the connector out of the way, and got the cover to open fully. But now it doesn't stay open. SC refastened the harness and tried to repair the cover mechanism, but concluded the hold-open spring has somehow gone missing - they couldn't find it. Replacing the whole console now.
  6. lloyds
    Bay Area
    Thats funmy - same here. Mine was working fine til I got the car back from the SC. Odd thing is they were replacing the front door latches, so it is odd how that affects the center console.
  7. adakeep
    adakeep New Member
    Punta Gorda, FL
    Same thing on model s. console door slides back about 2/3rd of the way. Also appeared right after service call. Based on the comments above I can also feel a couple of wires behind the door but my fingers are not long enough to moved them. Pretty sure the wires are the problem, just need to figure out how to get something in there to move them when I can't see or feel them.
  8. InsaneDriver
    InsaneDriver Member
    Miami, FL
    Had similar issue on my S until I realized you had to push down slightly to open. Never an issue since.
