Center console light?
Discussion in 'Roadster: Technical' started by jimmyz80, Apr 21, 2015.
  1. jimmyz80
    jimmyz80 Member
    El Dorado Hills, CA
    While installing my new stereo this weekend, I noticed something surprising. The bottom cover of my center console appears to have a light of some sort in it, as if it were designed to illuminate the little tray area on the floor below the center console. Do all roadsters have this, and has anyone ever seen it light up?
  2. hcsharp
    hcsharp Active Member
    Vermont
    Mine lights up.
  3. Chillout
    Chillout Member
    the Netherlands
    Mine lights up to... in a very nasty amber color. I've been wanting to replace it with a red LED, but the unit itself didn't seem that common, so I didn't bother looking for a replacement.
  4. m0rph
    m0rph Member
    Belgium
    Mine doesn't light up. I'll have to check it..
  5. jimmyz80
    jimmyz80 Member
    El Dorado Hills, CA
    Hmm what do you know....mine DOES light up haha. It's just so subtle that I never noticed it. Like Chillout mentioned above, I think I may have to swap in a brighter red LED to provide a little mood lighting for the Fusion Red car haha.
  6. Chillout
    Chillout Member
    the Netherlands
    The problem is the light is pretty hard to reach, you cannot just twist it and take it out. Also, the fitting is nothing I recognised on first sight... couldn't find anything useful when searching for the numbers on it...
  7. NomoC8
    NomoC8 Member
    Chi town
    Mine lights up.
    Maybe it's my aging eyes, but the interior lighting sucks. No map light, foot well, or acceptable dome light. I replaced the dome light w/ LED. Installed LED's in the foot wellls. It's switchable form red, for preservation of night vision, and white for finding your phone in the middle of the night.:cursing:
  8. Chillout
    Chillout Member
    the Netherlands
    I would love to see pics of footwell lights! And how did you install them?
  9. NomoC8
    NomoC8 Member
    Chi town
    I picked up a set of LED strip lights at one of the auto parts stores. They're adhesive backed with red and white lights. I stuck them to the bottom of the dash above the foot well. They came with a switch that cycles through white, red, both, and off. The switch is also adhesive backed. I stuck it under the center console toward the passenger side. I also picked up a electric mounting block. It has several spots for hooking up LED's. Each spot has its own on-off switch. It plugs into the 12v receptacle and has another on off switch. Ideally, I would rather hard-wire them, but I didn't want to challenge the warranty.
  10. Chillout
    Chillout Member
    the Netherlands
    that's looking great, thanks!
