Center Console Tray Lighting Hack
Sharing this hack to provide some illumination of the Tesla forward center console tray. With my older eyes, that forward tray is like a black hole at night without the overhead lights on. Now impressed that my old Subaru Forester had a ceiling mounted constant amber spot illumination of the console area.
Since there's already a fairly bright light in the bottom of the forward console, I drilled a pattern of holes in the back of the tray. That brought some light into the tray, but I then 3-D printed a frosted diffuser that did a better job. One future option would be to make a rectangular hole and 3-D print a diffuser with an embedded Tesla logo in a darker filament color.
If you decide to drill your own tray, highly recommend using Step Bits. They're the only sure-fire way to drill clean holes in thin plastic. Only issue is the "flocking" will need to cleaned up on the inside of the tray.
Decided to go bigger and add a logo. IPhone pics makes it look brighter than it is, but definitely helps illuminate that forward bin.
To make this mod, you'll need to create a 125mmx22mm rectangular cutout in the back of the console tray. I did this by marking out the perimeter with a ruler and marker, then using a cutoff wheel on my Dremel. Plastic is very soft, so it may gum up the wheel. You can clean up with a utility knife or file. Then used a little silicone around the perimeter to attach from the back. Including the diffuser STL for those that want to try it. I used Clear and Red PETG with a color change at the logo height.
  • Tesla Logo Tray Diffuser STL.zip
Looks good.
Since Tesla's optional front bin tray slides forward for access, I had an idea of reflecting the front bin LED light off the inside bin's top surface. Thought about doing this using a light weight acrylic mirror attached to the top of the bin.
There are flat surfaces on the bin top surface where the mirror could be attached. Here's a photo of the bottom of the lid sliding mechanism. Notice on the left side, the flat surfaces where a mirror could be placed.
Then I saw this inexpensive acrylic mirror film with adhesive backing. Only 0.2mm thick, so it would need a backing material to hold it when attached to the top.
Found this, a small piece of clear acrylic ( 200x200x1mm ). Could mount them to the top with double sided adhesive tape. If it does not work out, not much of a loss, and easy to remove.
This is definitely going to be copied by someone and sold on daZon.
Great work!
Reactions: BitJam
Looks good.
Can you share links to this website????
Is this Alibaba???
Is this Alibaba???
No, it is not Alibaba.com. It is AliExpress.com, which is the retail arm of Alibaba.com.
Here's are the links to the two product listings pictured in my post above.
4pcs Acrylic Mirror Stickers Thicken-2mm Self adhesive DIY Art Mirrors Wall Sticker
200x200mm plexiglass clear acrylic board, organic plastic sheet, 1mm
Keep in mind that the front bin's LED brightness is only slightly brighter than a sink hole abyss, so any reflected light will be similarly dim. As MDElectric stated in his post above "the IPhone pics makes it look brighter than it is".
Reactions: THEbuz
Thanks!
Maybe my LED is different. These are pics in regular IPhone mode, so pretty close to real brightness. I know some cars (Model 3) have a front-facing LED, which would not work with this mod.
