Centre Left Air Vent - not blowing
Discussion in 'The UK and Ireland' started by themetz, Jun 19, 2017.
  1. themetz
    themetz Member
    UK
    The centre left air vent on the dash isn't venting/blowing on my MS.
    So, out of the 4 front facing dash vents, only 3 are working.
    All vents are in the open position.
    Is this just a me issue?
  2. Haxster
    Haxster Member
    Silicon Valley
    There's an articulating plastic mechanism that can pop out of the damper. It's easy to snap back in, but not so easy to remove the panel from the dash to get to it. If you don't want to fix it yourself or take in in for service or close it very often, then you can probably poke a pen or screwdriver in the vent to force it open (it's easy to move without damage).
  3. themetz
    themetz Member
    UK
    Thanks for the reply. Had a good look in there with a torch, and, as you've suggested, looks like the mechanism has become detached somehow.
    Car is in for some other remedial work in a couple of weeks, will get the SC to sort this too!
