CHAdeMO Adapter (coming this winter)
Discussion in 'Model S: Battery & Charging' started by PattyChuck, Oct 5, 2013.
  1. PattyChuck
    PattyChuck Model S P100D, Model X P90D
    Valparaiso, Indiana
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
  3. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    Excellent news. That will make a lot of us happy, especially those in the Pacific Northwest where there are quite a few CHAdeMO chargers!
  4. NoMoGas
    NoMoGas Supporting Member
    Los Angeles, California, United States
    Pricey but this just opened up I-40 - Flagstaff
  5. dirkhh
    Portland, OR, USA
    Definitely not cheap... But this will help when you are traveling off the supercharger enabled main highways. And when you are at your destination.
    And it increases the incentive for people to put in CHAdeMO chargers!
    70 miles/h is not supercharging but it's much better than AC charging for those of us with just a single charger. And cheaper than a second charger, too!
    I'll definitely try to pre-order mine.
  6. apacheguy
    apacheguy S Sig #255
    So Cal
    Whoa! Sticker shock for sure. 70 mph isn't great either - I would have expected better. I'm happy with superchargers.
  7. Puyallup Bill
    Puyallup Bill Member
    Puyallup WA
    #7 Puyallup Bill, Oct 5, 2013
    Agreed not cheap, but much less than I had anticipated. Great for us in the NW. And, if the depiction is actual, a neat package.
    Edit: On second thought, those CAHdeMO nozzles and cables are not exactly light weight - looks like a lot of weight hanging on the charge port. Perhaps something like the Roadster adapter, where the heavy nozzle and cable lay on the ground.
  8. Cottonwood
    Colorado
    Something is not adding up...
    From Shop Tesla Gear CHAdeMO Adapter:
    Take advantage of CHAdeMO’s network of 50 kW charging stations by enabling onboard hardware and purchasing an external adapter. CHAdeMO stations charge at the rate of approximately 70 miles of range per hour of charge with locations primarily in the Pacific Northwest.​
    A 10kW 14-50 gives you 28 mph charging, and a 20kW HPWC provides 56 mph charging. Scaling from that, 50kW should provide 140 mph charging. Is this adapter throttled to 70 mph or 25kW? If so, was that done as a cost savings measure, as a marketing decision, or both?
  9. Osiris
    Osiris Member
    Germany, Munich
    Now we Europeans just need a Frankenplug-Adapter! The Frankenplug adapter should be an easy job, compared to CHAdeMO Adapter?!
    Bye the way, I like how Tesla integrated Type 2 into our Teslas. I like I can use Type 2 Charging Stations and will be able to to fastcharging via Type 2. Nice job charging-team @ Tesla.
  10. Zextraterrestrial
    Humboldt/Los Altos
    agree CW, 50 kW should be at least 125 mi/hr
  11. ZBB
    ZBB Emperor
    Scottsdale
    Interesting... But pricing looks more favorable for new buyers:
    So its $1k for existing owners that have Supercharging enabled.
    But existing 60s that don't have Supercharger enabled pay only $400 in addition to enabling Supercharging. And if you haven't taken delivery, looks like you can add this for $400 if you enable SC too...
  12. gaswalla
    gaswalla Model S,3,X.. CT with Austin delivery
    San Diego
    The details say it charges at 70 mi/hr.. Isn't it faster than that? That's the same as dual chargers.
    Edit... Others have noticed this too
  13. trils0n
    trils0n 2013 P85
    SF Bay Area
    Nice, can't wait to get this adapter. I've had a number of situations where it would have been really helpful.
    Are all CHAdeMo stations 50kW or do they vary like level 2 J1772s?
  14. ggbjr
    ggbjr Member
    NC
    Right. Was wondering that. For those without supercharging enabled, does an adapter purchase actually enable Supercharging or just the "hardware features" required for CHAdeMO
  15. dsm363
    Nevada
    So for 85kWh cars it is still $1,000 after delivery?
  16. Puyallup Bill
    Puyallup WA
    Are those rated miles, or ideal? Seems Tesla usually touts ideal miles, and 70 ideal is not really that great. If ideal, that is about 60 rated, right?
  17. TonyWilliams
    TonyWilliams Active Member
    San Diego - Tesla powered Rav4 EV
    Guys, the CHAdeMO standard is currently 500 volts * 125 amps = 62.5kW, and that's not 70 miles per hour!! But, Tesla may have de-rated this adapter to something far lower... we'll know soon.
    Since the Tesla products are slightly under 400 volts, the max charge rate from CHAdeMO will be 125 * 400 = 50kW.
    At 95% efficiency, let's say 47.5kW, ok? That is 142.5 miles per hour with 3 miles per kWh / 333 watts per mile driving efficiency. Just like the Supercharger, as you get to the top half of the battery charge, the charge rate will start to come down, but I don't image that will happen until about 80% SOC.
    Of course, not every CHAdeMO installation is rated for 62.5kW !!!
    All of the Nissan branded Sumitomo units are only 44kW. The Fuji units, like the one in San Juan Capistrano, California is only 25kW.
    In the future, when CHAdeMO is opened up to 200 amps, you can expect 200 * 400 = 80kW * 95% = 76kW, or about 228 miles per hour charging!!!
  18. brianman
    brianman Burrito Founder
    I'm fairly confident Tesla looked at the "general pattern of chargers currently available" and picked the 25kW cases (such as the Fuji units apparently) and probably drew some number from that.
    I highly doubt they've added additional limiting, so I'm not concerned just yet. :)
    And, yes, I've already sent mail asking Tesla to start a pre-order list.
  19. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Does Chademo support the car instructing the charger to ramp down amperage as the battery fills up? If not, then maybe 25kW is the maximum safe charging rate.
  20. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Interesting. Not the design I was told to expect a while back.
