CHAdeMO Adapter (coming this winter)
islandbayy
2,644
1,015
Greendale, Wisconsin
Still pricey, I think I would add a dual charger for a bit more before getting this. Unless, my idea, at least in my area I know 4-5 other MS Owners, a idea (If everyone is comfortable with this) is to pool the money for one, and share it as needed. Since it's really only needed for road trips, whoever is most likely to use it will take it with them, and just bounce it back and fourth as needed. I know it may be handy when going to Dallas/Plano this winter.
scottf200
3,785
3,349
Chicagoland ModelX S603
Whoa! Sticker shock for sure. 70 mph isn't great either - I would have expected better. I'm happy with superchargers.
I wonder if the infrastructure/installation of the chademo chargers are *mainly* setup for ~25kW max charging which seems to be what the LEAF (and i-MEV) does?
That is to say Tesla would not want to overtax those chargers and cause a problem. Read: bad PR and backlash from the chademo community.
Charging Power as a Function of Time - EPRI LEAF
EPRI - Elect Power Research Institute - http://www.epri.com/Pages/Default.aspx
Battery Capacitor and State-of-Charge - EPRI LEAF
stopcrazypp
9,877
4,801
I'm guessing Leaf owners to should chime in. They probably know the actual average and peak charging speeds at the 50kW chargers.
- - - Updated - - -
I don't know enough about the CHADEMO standard but I don't understand why the adapter is $1000, that seems outrageous to me. Why is it so much more than other adapters? Can someone explain why the CHADEMO makes the adapter so complicated and expensive?
There's a couple things. First, the CHAdeMO socket itself is expensive (don't remember off the top of my head but definitely over $100, maybe a couple hundred). Second, it has to handle more power, and as jerry33 points out, it's more complicated than the UMC. I would have expected it to cost even more.
The only thing that makes it not really that worth it is if it's really derated to 70mph. If it's full power (140mph) then I think $1k is probably still worth it for the people who need it.
scottf200
3,785
3,349
Another interesting graph about i-MiEV and LEAF charging with a Fuji charger (found Fuji presentation with following)
Google search: charging power leaf chademo chart 80% filetype:pdf
ZBB
Emperor
Feb 27, 2013
1,543
267
Scottsdale
Admittedly I wouldnt use it much around town. As you said, Tucson trips perhaps, and certainly for LA trips, quite a few out there. Getting to SCs while in LA may not always be easy (assuming I can get to LA at some point in the future). So having access to use Chademo would be helpful. And I'm assuming there will be some future buildout, though it's not a given. I like (as Elon would say) "optionality".
I was figuring you'd say for LA trips -- I could see it being handy for a road trip once or twice a year (once the SC gap from PHX to LA is bridged)...
The way I see it, I'd need to use this adapter at least 30 times to justify the cost, especially if it would only be used on a couple trips a year. Wonder if Tesla would consider renting them for ~$100/week? Either that, or get 4-5 locals together and go in on a shared one...
Palpatine
Banned
Sep 6, 2008
1,354
-1
Seattle
That is my thought also. Get a group of 3-4 local Tesla owners you know and have a shared Chademo adapter.
SteveW25561
614
120
Vancouver, Canada
I think this is a terrific additional option but clearly the value proposition is dependent on local availability -- just for context I thought some maps would help. These are from the CHAdemMO.com's own Google map of stations (
http://www.chademo.com/kml/CHAdeMO_map_in_130817.kml)
Here's a map of North America: WA & OR residents stand to benefit the most.
But you can see why the European market would really need a CHAdeMO solution, especially since there is a paucity of Superchargers there:
Not to mention Japan (wow!) (http://www.chademo.com/kml/CHAdeMO_map_jp_1004e.kml):
dirkhh
Middle-aged Member
Jul 7, 2013
3,638
126
Portland, OR, USA
That was my thought as well. I'd buy one and then rent it out to others in the area for $50 a week. Unlikely to make me money, but should at least offset some of the cost. And the only one with an upfront investment is me (so no need to create a little club with bylaws and rules and reasons for things to go south...)
efusco
Moderator - Model S & X forums
Mar 29, 2009
5,421
666
Nixa, Missouri, United States
SteveW.....
Thanks, those maps are interesting and helpful, but would be more helpful with the Tesla Superchargers superimposed on them. I think that would give a more complete network picture.
scottf200
3,785
3,349
And this corresponds to what the adapter shop pages states:
http://shop.teslamotors.com/collections/model-s/products/chademo-adapter
Take advantage of CHAdeMO’s network of 50 kW charging stations by enabling onboard hardware and purchasing an external adapter. CHAdeMO stations charge at the rate of approximately 70 miles of range per hour of charge with locations primarily in the Pacific Northwest.
efusco
Mar 29, 2009
5,421
666
At $1000 this isn't something I'm going to jump on just to have on hand as it's likely something I would rarely need. In fact, the better option might be if Tesla would loan them out rent them out on an 'as needed' basis. I'd much rather pay $100 to rent one for a trip I expect to need it for rather than to buy it outright and maybe only use it once or twice the entire time I own the car. Maybe an entrepreneurial owner will start his/her own rental program.
jerry33
Mar 8, 2012
19,525
21,731
Texas
The ChaDeMo map looks just as blank as the Supercharger map for the places I would like to travel to.
bluetinc
760
176
MD
That map for the US looks quite out of date. It definetly was missing quite a number of ChaDeMo stations that I know on the East Cost. Here is the Plugshare map that is much more up to date.
Peter
Mario Kadastik
2,189
1,396
Rae, Harjumaa, Estonia
heh, always fun to see our small Estonia on those maps. We've got some serious amount of 50 kW chargers and I'd be very interested in a full 50 kW charger as 25 really is no step up from the twin charger capacity that every single charger in Estonia can do with Type-2 connector next to CHAdeMO at 22kW.
Denarius
1,378
84
Utah
lol, I thought of you when I noticed how dense the chadmo chargers are in Estonia!
stopcrazypp
9,877
4,801
The European adapter will be different than the US one, so it's still possible for it to be 50kW even if it's confirmed the US one isn't.
RDoc
S85D
Aug 24, 2012
2,719
1,567
Boston North Shore
Something to consider depending on where you might use this, is the buildout of the SAE Combo charging plug stations. The stated plan is for many government/power company CHAdeMO chargers to be retrofitted with an additional SAE Combo Plug in the next couple of years, so for many non-Nissan charging points, the CHAdeMO adapter may not be needed. Of course, that's not going to happen overnight.
Presumably Tesla will offer a compatible adapter, or perhaps better, just replace the current J1772 with a Combo plug adapter. The cost shouldn't be much more for the Combo plug than the J1772.
