garygid
Some of the CAN MsgIDs (hex) seen on the pseudo-CAN Pilot line:
(data bytes D1 through D8, I3 is 2-byte integer in D3 and D4)
[This info is as I recall, with guesses and some unknowns, and
might be incomplete, or wrong. Use any info at your own risk.]
Apparently from the car (8 MsgIDs):
102: I1 / 13.8 amps requested by car
112: Unknown use
202: I1 / 14.01 voltage measured by car
202: I3 / 54.6 amps measured by car
302: D3 * 1.0213 State of Charge as Range Miles
30C: Unknown use
312: I5 Unknown use
322: D1 VIN field Index = 0, 1, 2
322: D2 thru D8 a field of car's 17-character VIN
(D1==0 is 1st 7 chars, D1==1 is middle 7, D1==2 is last 3 chars plus 4 zero bytes)
3D2: D1 through D4 unsigned integer Total Wh sent to Battery
Apparently from the SpC (3 MsgIDs):
214: D2 (xxEu AxCD) flags showing charging state
214: I5 / 13.73 amps delivered by SpC
214: I7 / 13.7 voltage from SpC
x = non-zero not observed ?
E = ? car requesting Excessive amps, more than available ?
u = unknown meaning
A = Active charging in progress ?
C = Car Connected to SpC, authorizing, testing GFI ?
D = DC contactor is closed (HVDC path from SpC to Car)
244: I1 / 16.3 max power (kW) available from SpC
244: I3 / 15.5 max amps ? available from SpC
514: D1 SpC Serial Number field Index = 0, 1, 2
514: D2 thru D8 a field of SpC Serial Number
Sample SpC Serial Number = "sc00000000000nnnn"
Please let me know of any errors or additions, so
that I can edit / correct / improve this post.
Are all of these MsgIDs observed in the CAN3 logs?
Thanks, Gary
112: Unknown use
30C: Unknown use
312: I5 Unknown use
u = unknown meaning
Thanks, Gary
