Nigel Tufnel
I should remember the world doesn't revolve around California, I sleep too much, and should re-read M. Scott Peck's "The Road Less Traveled".
What you're missing is not everyone lives in California. Essentially everyone can choose a route that has a supercharging station along the way? Really? Have you ever traveled away from the west coast?I'm not an EE, nor the brightest bulb in the chandelier, so maybe someone can take the time to explain what I'm missing here? Essentially everyone has, or can get 220V at their home. Essentially everyone sleeps, most of us at night when electricity rates are often cheap. Essentially everyone has a UMC or can get one. And when one travels, essentially everyone can choose a route that has a supercharging station along the way.
It appears that even the EMW "High Voltage" DC Power Supply will not go up to the Voltages needed for an 85/90 kWh Tesla. At Electric Motor Werks, Inc. - QuickCharge-25000 HV - a 25kW PFC charger for HIGHER voltage batteries, it states: "There is only one limitation – you can only charge battery packs with end-of-charge voltage above the peak of the rectified AC wave (~340V from the 240VAC supply)" You need over 400 Volts DC for an 85/90 kWh Tesla.
Read it again.
You can only charge battery packs with end-of-charge voltage above the peak of the rectified AC wave. Because the 85/90 kWh Tesla is ~400V, it is indeed above the peak of the rectified wave. It's only an issue if your battery pack was a 300V battery pack that the higher voltage would be an issue.
I would hope that any Tesla or EV owner that would rely on an at-home DC charger would not bet on a homebrew solution to save money. Sure, for a hobbyist, I think it's great.
From the very beginning, the product doesn't meet the CHAdeMO specs of 50-500 volts.
I just got in my CHAdeMO adapter, which I ordered from Tesla. Since it is pretty clear at this point that the Model X onboard charger will be limited to 48 amps (12 KW), this CHAdeMO adapter provides a much needed option when out on the road, and not near a supercharger. Since the CHAdeMO can DC fast charge at up to 50 KW, it is about 4X faster than the onboard charger.
A nice addition for road trips, even some places within California. Might even consider putting in a CHAdeMO at home.
Ron
SigX VIN #484
Does it look like it is worth $450? I will be getting one, especially since the Model X is being stuck with a 48Amp onboard charger, so hopefully there will be CHAdeMO chargers where there may not be SuperChargers.
How did you come up with that number? Do you know what it took for Tesla to come up with a reliable CHAdeMO adapter for all the different iterations of CHAdeMO charging stations out there? By the way do you know the original price was going to be $1000, and there was a waiting list for it at that price?I'd say that the $450 price tag is a bit steep -- I'd guess a $300 item retail elsewhere -- but since it is only available from Tesla, it is what it is. I think that it is definitely worth the money to have another quick charge option out on the road. See muleferg's review at the top of this post. He has one that he uses on his Model S and loves it.
Hit or miss with Nissan. Some allow, some don't. Some are only open during dealership opening hours.
I see it both ways... $35,000 for a 50-500 volt charger that will cover every type of CHAdeMO vehicle that you might encounter plus the required three-phase power feed, or $4,200 for a model that's limited to battery packs >= 350V rating and can do 240V single-phase at up to 25 kW
