CHAdeMO Initial Impressions...
Discussion in 'Model S: Battery & Charging' started by tcampos, Feb 18, 2015.
  1. wycolo
    wycolo Active Member
    WA & WY
    > I was thinking of some sort of strap that could hook on the handle, then inside the trunk. It should be pretty easy to rig something up. [liuping]
    If you tie a string temporarily as described then you can balance the whole enchilada on your outstretched index finger, i.e no twisting force on the charge socket. Kinda like when you park at just the right distance with the SpC plug. Got some string?
  2. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    If it breaks the charge port, I'm just going to call Tesla and they're going to replace it since it would be their design flaw. So, not really going to worry.
    But again, I don't think it's heavy enough to cause concern. The supercharger cables are pretty heavy, and they usually have to be turned and such to make it into the port which puts some torque and weight on it too.
    Not concerned either way, especially since I won't be using it often anyway (probably a few times per year).
  3. tcampos
    tcampos Member
    I have similar feedback. it doesn't seem to be an issue, and the CHAdeMO ports look a lot heavier than they actually are. It doesn't seem to be creating undue pressure.
  4. wk057
    Hickory, NC, USA
    Yeah, they're just huge, but not heavy.
  5. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    I received my Chademo adapter today, so I took it for a spin. The charger I went to was an evGo one. I signed up for the eVGo network a few days ago, but hadn't received my RFID card yet, so when I got to the charger, I just called the 800 number, gave them the station ID printed on the station and they enabled it for me.
    Here's a picture of the station, a slim Nissan unit.
    Here's the name plate at the back:
    True to its rating, I was pulling 41kW from the unit (according to the car). For this test I ran it for 15 minutes. Nothing got warm, just some some warm air blowing out the back of the pedestal from three muffin fans.
    The only catch was locking the bulky chademo handle to the adapter. This type of handle has a lever that is used to lock them together. So fit the pieces together and then squeeze the level/trigger to lock them together.
    As far as weight is concerned, I'm not worried. The Tesla connector can handle it.
    All in all, a very straightforward experience. Thanks, Tesla!
  6. andrewket
    andrewket Well-Known Member
    Does evgo not have any pay as you go plans? All I see is monthly?
  7. Cosmacelf
    San Diego
    Yes, evgo has a pay as you go.
  8. republic
    republic Member
    District of Columbia
    By the looks of it, the pay as you go plan is quite expensive and not worth it if you plan to charge more than once a month.
  9. artsci
    artsci Sponsor
    Timonium, Maryland
    Looks like Rube Goldberg was the lead desinger on the CHAdeMo device. That sucker is an ugly spunk.
  10. Six
    Six Member
    When I compare the various "standard" DC fast chargers to Tesla it looks like all but the Tesla design were done by people who wanted EVs to fail.
  11. brianman
    brianman Burrito Founder
    There's some nuance here that shouldn't be overlooked. It depends upon whether the second car happens to choose the "worst possible choice" for slots at the supercharger. At sites with 2 supercharger plugs, this is 100% likelihood. Most sites have more than 2 plugs though.
    - - - Updated - - -
    That's one conclusion. Others include incompetence, lack of interest or concern for user experience, and over-concern for "zomg electricity scary".
  12. AB4EJ
    AB4EJ Member
    Tuscaloosa, AL
    Nissan helping out?
  13. andrewket
    My use is likely going to be situational on road trips. Supplement to superchargers. In that case I'll be happy to pay more.
  14. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Agreed. Or, more likely, you're just seeing the difference between something that was designed by engineers vs. something that was designed by designers.
  15. artsci
    artsci Sponsor
    Timonium, Maryland
    For sure. This kind of technology does not have to be ugly. Imagine what an iPhone would look like if were designed by the people who designed the CHAmeDO and other chargers pictured. Tesla clearly gave serious thought to aesthetics when it designed its plug. Cheers!
  16. Merrill
    Merrill Active Member
    Sonoma, California
    Ok, so tell me why I need a chademo if I have Superchargers I can go to for free.
  17. Benjamin Brooks
    San Jose, California, United States
    Because a CHAdeMO charger may be less out of the way than a SC for some destination you're trying to reach. As SC network grows, that likelihood obviously drops.
  18. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    You don't. But not everyone lives in a state with the density of superchargers that California has.
  19. trils0n
    trils0n 2013 P85
    SF Bay Area
    Also helpful for someone like me who only has work charging (no home charger). There are 3 CHAdeMOs within 2.5 miles of my home. Nearest Supercharger is nearly 20 miles and a toll bridge away.
  20. Cosmacelf
    San Diego
    Even in California, there are times when I will need a fast charge, with no Supercharger near by. The Chademo adapter is a very welcome piece of gear for those who drive a lot. Kudos to Tesla for making it.
