The one I got recently worked fine when I tested it. Since it's the kind of thing you typically only need in emergencies, it's a good idea to make sure it works, and can return it for a working one if you got one that doesn't work. So try it again at a different charger. And make sure you connect it to the charger first, the car second, and then turn on the charger.
