Change from 110 volts to 220 volts
Discussion in 'Roadster: Technical' started by lmore, Feb 20, 2013.
  1. lmore
    lmore Member
    Trondheim, Norway
    I have a US Roadster that I'd like to modify so it becomes like the European Roadster in that way that it charges at 220-240 Volts when no pilot signal is present. Any idea how to modify the car to archive this (my warranty is void)?
    I'm using the MC240 charger for now since it gives the pilot signal to charge at 220 Volts. The problem is that it is a bit big to carry around.
  2. widodh
    widodh Model S 85kWh
    Middelburg, The Netherlands
    I think this is a firmware thing.
    In Europe it won't charge over 13A when no pilot signal is present, so that will be your limit.
    Have you actually tried to put 220V on the pins without a pilot? I don't think it can hurt since the charger is able to accept it.
    It will charge (or not).
    The Amps are the problem for the cable, not the volts.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Perhaps this is something that can be adjusted through the touchscreen maintenance features? Have you ever tried asking Tesla if it could be adjusted?
  4. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    #4 dhrivnak, Feb 21, 2013
    I have tried this with no success. I made an adapter to try and the car would not charge. I have not seen anything in the VDS that would allow an override.
  5. Doug_G
    Ottawa, Canada
    Get a small, portable J1772 charge station with the appropriate current rating, and wire a plug onto it.
  6. lmore
    lmore Member
    Trondheim, Norway
    Thanks for the advice! Yes, it is probably a firmware issue since they changed the limit from 16 amp to 13 amp in Europe recently (my first European Roadster could at least charge at 16 amp).
    I ordered a European charger from Tesla telling that I had a US car and they sent it to me, but it did not work... So why could they not just say that they could modify the firmware instead of me having to return the cable? I will ask again.
    I'd like to add the pilot signal to the chargers I have (and currently cannot use) so I could choose the ampere. I see there are suggestions on how to do this on the forum, if someone that did it could sell a kit that would be great.
    What J1772 charge station do you suggest?
    I found this: Lincomatics DIY Blog | electronics, 3d printing, hacking, etc
